Bulk Data Entry Defines a multibody solver variable which can be
        referred to by multiple expressions.
                            | MBVAR | VID | EXPR |
                            | MBVAR | 3 | IMPACT(Dz(30301020,30302040),VZ(30301020,30302040),0.0,4 |
                            |  | 00,1.0,0.5,0.000) |
                                | VID | Variable
                                    identification number. (Integer > 0) |  |
                                | EXPR | Character string
                                    expression. The expression can spawn multiple lines. The
                                    continuation lines will start from the second column. Refer to
                                        Function Expressions. |  |
            - The variable ID can be referenced by
                    VARVAL(VID) in multiple expressions in the model.
