Altair Multiscale Designer 2025 Release Notes
Highlights
  • Single Scale Material Support for Forward and Inverse Characterization
  • Support of a generic user material class
New Features
User-Defined Material Class
The user-defined material class allows the combination of any elastic law with any supported inelastic or damage law. It can be used to define any needed single scale or constituent material behavior, which is not covered be the predefined material classes (polymer, fiber, tow or metal).
Supported combinations are:
Elastic Symmetry Inelastic Law
Isotropic Isotropic bilinear brittle damage
Isotropic 3-piecewise brittle damage
Orthotropic bilinear brittle damage
Orthotropic 3-piecewise brittle damage
Rate independent plasticity
Rate dependent plasticity
Hybrid rate independent plasticity and isotropic damage
Hybrid rate independent plasticity and orthotropic damage
Trans-isotropic Isotropic bilinear brittle damage
Orthotropic Isotropic bilinear brittle damage
Single Scale Material Profile
The Single Scale Material Profile supports forward characterization as well as inverse characterization processes.
All types of material classes (user-defined, polymer, fiber, tow and metal) are supported in the new Single Scale Material Profile.
Figure 1. Single Scale Inverse: Input Definition
Figure 2. Single Scale Inverse: Result Review
