Altair HyperLife 2024 Release Notes
Highlights
  • Updates to HyperLife licensing and installation
  • Support of random fatigue analysis for spot weld
New Features
Licensing and installation
HyperLife 2024 will require installation of both HyperWorks Desktop and Solver packages. Installation of HyperLife via Solvers is a prerequisite for Stress Life, ERRI and IEC fatigue evaluation using HyperLife Weld Certification.
HyperLife 2024 introduces license feature HyperLifeSolver following solver licensing scheme for InApp and HPC based evaluation. The Altair unit draw will depend on the number of CPU cores assigned for the HyperLife job. The HyperLife Solver license feature is required for Stress Life, ERRI and IEC evaluation in HyperLife Weld Certification. HyperLife session for setting up workflows will continue to use license feature - HyperLife.
Random response fatigue for 1D Spot welds using FRF analysis and PSD Input is supported. The feature supports H3D result format as input.
Support of node sets
Stress Life, Strain Life and FOS fatigue evaluation at node is extended to support node sets as input.
Bergmann model for mean stress correction
Strain Life uniaxial analysis supports Bergmann mean stress correction. Bergmann method is an extension to SWT introducing a parameter ‘a’ to account the mean stress sensitivity of the material.
Support for H3D result file from PERMAS for Stress Life, Strain Life and Dang van FOS with time series loading
Support of scale and offset in modal superposition fatigue event
Option to scale and offset Modal participation factor per mode at time t is supported for fatigue events created during modal superposition loading.
Enhancements
Fatigue evaluation of nodes is extended to mid-edge nodes in second order elements
Rainflow output (RFOUT) of random fatigue and sine sweep fatigue to report corrected stress amplitude
Rainflow file from random fatigue and sine sweep fatigue analysis will also output corrected stress amplitude along with stress amplitude, mean stress and damage for every cycle.
Run Setup XML is enhanced to list safety factor options for batch evaluation
Resolved Issues
  • The issue concerning reloading of stress life point,1-segment and 2-segment curves is MyMaterial dialog is resolved.
  • HyperLife experiencing performance issue while writing rainflow matrix file “ElementRainflow.h5” is resolved.
  • The issue concerning correction of stress life curve of XY data format with surface finish, surface treatment, fatigue strength reduction factor and temperature factor is resolved.
  • Same stress/strain history output per event from advance options is resolved.
  • The issue pertaining to evaluation of nodes using element sets as input is resolved.
  • Displaying 3D matrix for damage and rainflow from stress life and strain life evaluation using Abaqus result files is resolved.
  • Inconsistent issue concerning empty callouts and damage matrix for SPOT weld fatigue is resolved.
  • The damage matrix is not appearing for the attached customer use case.
Known Issues
The following known issues will be addressed in a future release as we continuously improve performance of the software:
  • The HyperLife Solver license feature also supports a decay factor, facilitating reduction in the total license draw if multiple HyperLife jobs are running simultaneously. For using the decay functionality, please contact Altair Support for assistance in installing this feature.
  • Elements occasionally reporting NA results when the stress gradient feature is combined with Strain Life evaluation. The issue is inconsistent and will be fixed in the upcoming release.
