Synchronous machines – Wound field– Motor Factory – Test environment
Error when performing test working point P, Pf, U, N
This error occurs when using the generator convention and the motor operating mode.
Note: Same issue while exporting the corresponding
connector for HyperStudy (ref.: SLVFXM-18286).
SSFR - Negative values of the equivalent scheme
We met a few cases where the parameters of the resulting equivalent scheme were negative (ref.: SLVFXM-10916).
