Synchronous machines – Motor Factory – Export environment
Export from FluxMotor to FEMT - Issue when exporting the Efficiency map test in case of parallel paths.
This problem occurs when there is more than one circuit in parallel for the periodic portion of the model under consideration (ref.: FXM-17103).
SMPM - issue while exporting a 3D machine with a shaft
The shaft is not represented in the resulting 3D project (ref.: FXM-17953).
