Slot
Overview
In Motor Factory – Design area, the environment “Slot” allows to design the shape and the dimensions of the machine slots.
For Inner Rotor machines, three sections are available: Design, Lamination and Skew.
For Outer Rotor machines, two sections are available: Design and Skew.
Table 1. Slot design area (example for the inner rotor topology machine)
1 Selection of the Slot panel (Click on the icon Slot).
Several sections allow defining all characteristics that deal with the Slot: Design, Lamination and Skew.
Note: Lamination is available for inner rotor topology but not for outer rotor topology.
2 The design tab gives access to the section dedicated to the design of the slot.
Note: By default, the section Design is selected.
2.1 Selection of the shape and settings of the user inputs dedicated to the design of the slot.
3 The lamination tab gives the tools to define the shape of the lamination.
Note: This section is only available for inner rotor topology machines.
4 Skew tab gives the tools to define the slot skew topology.
Subsections
Design
For more details, please refer to Design.
Skew
For more details, please refer to Skew.
