Design
Type of frame
In this section, three choices are available to define the type of frame topology: None, Circular or Square.
By default, housing type is set to “None”. There is no frame.
Important: When “None” is selected, access to
External cooling and Internal cooling environments is locked.
| 1 | Default setting: Housing type is « None ». The machine has no frame. |
| 2 | Button to select a circular-shaped frame. |
| 3 | Button to select a square-shaped frame. |
Circular shape
| 0 | Definition of the Connection Side (C.S.). It is identified by yellow lightning. The other side is called the Opposite Connection Side (O.C.S.). This helps to easily differentiate between both sides of the machine. |
| 1-5 | User input parameters to define frame dimensions in the axial view. |
Square shape
The user inputs for defining the frame dimensions in the axial view are the same as
in the case of the circular shape frame.
Important: The square shape topology is only available for inner rotor
topology.
Note: The inner length of the square shape
frame is automatically defined by the stator outer diameter, which is defined as
structural data in the specification.
Note: The
illustrations below are based on the SMPM-IR machine. However, the principles
described apply to all machine types, including the IMSQ-IR for
instance.
Validity domain
Here are the allowed range of values of the frame dimensions in the axial view:
- Thickness of the frame: ]0, 50] mm.
- Connection side extension: ]0, 20000] mm.
- Connection side – End-plate thickness: ]0, 50] mm.
- Opposite connection side extension: ]0, 20000] mm.
- Opposite connection side – End-plate thickness: ]0, 50] mm.
Combination between lamination outer shape and frame types
| Frame type | ||||
| None | Circular | Square | ||
| Lamination outer shape |
None |
| Circular |
| Square |
| Circular shape lamination & Circular shape frame |
Circular shape lamination & Square shape frame |
Square shape lamination & Square shape frame |
