Depuis la version 2026, Flux 3D et Flux PEEC ne sont plus disponibles.
Veuillez utiliser SimLab pour créer un nouveau projet 3D ou pour importer un projet Flux 3D existant.
Veuillez utiliser SimLab pour créer un nouveau projet PEEC (pas possible d'importer un projet Flux PEEC existant).
/!\ La documentation est en cours de mise à jour – des références au 3D peuvent subsister.
Removal of Modeler and CAD import/export
Why?
For strategic reasons, the external geometric kernel library (ACIS), which allows to build a geometry via the modeler and to export/import CAD files, has been removed.
Consequences
The impact of removal of Modeler and CAD import/export is mainly for Flux 3D (which is also removed in Flux 2026, see Removal of Flux 3D / Flux PEEC) but also for Flux 2D.
Flux 2D is still accessible in Flux 2026, but CAD import/export is now not possible in Flux 2D also.
Recommended ways
The recommended ways to build a geometry are:
  • use SimLab to create your geometry and to achieve your EM study
  • use another tool to build a CAD geometry and use SimLab to import this CAD file and achieve your EM study
What's happening to previous releases (Flux 2025.1 and below)
The geometric kernel library (Modeler and CAD export/import) is always delivered with Flux 2025.1 and previous versions. You could always use these versions.
What's happening to Flux 2026 and future releases
For Users:
  • With Flux 2026 (and future versions)Flux 3D being removed, it will be impossible to open your 2025.1 (and previous versions) Flux 3D project with Flux 2026 (and future versions)
    A faire : use SimLab (Import Flux project) or a previous Flux version
  • With Flux 2026 (and future versions), it will be possible to open a 2025.1 (and previous versions) Flux 2D project:
    • without CAD file (no change)
    • with CAD file (with internal processing of the project when the project is opened): the CAD file will be cleaned and the project renamed "ProjectName_2026.FLU"
      Important : The 2025.1 (and previous versions) 2D project must be meshed to be able to open it with Flux 2026.
User possibilities of opening 2025.1 (and previous versions) projects with Flux 2026
USER Meshed Not Meshed
Without CAD With CAD Without CAD With CAD
2025.1 (and previous) Flux 2D project
2025.1 (and previous) Flux 3D project
(Use SimLab: Import Flux Project in SimLab)
Important : If you have some issues with your 2025.1 (and previous versions) projects (with or without CAD file), you could continue to contact our support team which will be able to analyse your project and support you.
The only configuration that is not supported is a project not meshed with CAD, so mesh your project before to exchange it with support team.
