Geometry imports (standard formats)
Introduction
This section deals with the import of geometry starting from geometry files.
The import of a CAD geometry in a FE (finite elements) project is an operation consisting of turning the data from the CAD type (in a specified format) into data of the FE type.
Formats
The following formats enable geometry import:
| File format | Extension | Type of format |
| DXF (Draw eXchange File) | *.DXF | standard |
| FBD (Flux 2D géométrie) | *.FBD | proprietary |
