PBS Flux Examples
Here are some Flux examples directly ready to be run via PBS.
2D examples
ExampleDocumentsIllustration
Magneto Static application - Sensor
Summary
MagnetoStaticApplicationSensor_FluxAndPython.zip
With one Flux File and python files to drive the solving and postprocessing process
MagnetoStaticApplicationSensor_PythonFile.zip
With one python file to drive the construction of the geometry, the physic setting, the solving and postprocessing process
MagnetoStaticApplicationSensor_Python.zip
With multiple python files to drive the construction of the geometry, the physic setting, the solving and postprocessing process
MagnetoStaticApplicationSensor_Flux.zip
With one Flux File. In this case we will solve the existing scenarios (no postprocessing)
3D examples
Example Documents Illustration
Linear Actuator
Summary
LinearActuatorParam_FluxAndPython.zip
LinearActuatorParam_PythonFile.zip
LinearActuatorParam_Python.zip
LinearActuatorParam_Flux.zip
