About other software – supported version
Supported versions of software whose coupling is possible with Flux
External software
The coupling between Flux 2025.1 and other external software can be achieved with these versions:
| External software | Supported version | Supported OS |
| Simulink | 2023 a&b, 2024 a&b | Windows |
| Matlab | 2022 a&b (Java and Native mode) 2023 a&b (only Native mode) 2024 a&b (only Native mode) |
Windows / Linux |
| Microsoft Excel | 64 bits | Windows |
Altair software
The coupling between Flux 2025.1 and other Altair software can be achieved with these versions:
| Functionalities | Altair software | supported version (and above) | Windows 10 & 11 |
Red Hat Enterprise Linux 9.4 and CIQ Rocky Linux 9.4 |
| Co-simulation | Activate | 2025.1 | ||
| Export to.. (Thermal analysis) | AcuSolve | 2025.1 | ||
| Export to .. (Vibroacoustics and mechanical analysis) | OptiStruct | 2025.1 | ||
| Shape optimization | OptiStruct | 2025.1 | ||
| Flux driven by.. | Compose | 2025.1 | OML language: Python language: |
| Material Identification | Compose | 2025.1 | ||
| Mesh import | HyperMesh | 2025.1 | ||
| Mesh import | SimLab | 2025.1 | ||
| Parametric optimization | HyperStudy | 2025.1 |
ACIS - InterOp : Format and Version Supported
Flux 2025.1 is compatible with ACIS 2024 1.0 version.
| Format | Extension | Supported version by ACIS 2024 1.0 |
| ACIS | .sat, .sab, .asat, .asab | R1 – 2024 1.0 |
| CATIA V5 | .CATPart, .CATProduct | V5R8 – V5–6R2024 |
| DXF | .dxf | 2.5 - 2024 |
| IGES | .igs, .iges | Up to 5.3 |
| Inventor | .ipt (V6 – V2017) | V11 – 2024 |
| NX | .prt | 11 – NX 2312 |
| Parasolid | .x_t, .xmt_txt, .x_b, .xmt_bin | 9.0 – 36.0.169 |
| Pro/E /Creo | .prt, .prt.*, .asm, .asm.* | 16 – Creo 10.0 |
| SolidWorks | .sldprt, .sldasm | 98 – 2024 |
| STEP | .stp, .step | AP203, AP214, AP242 |
| Format | Extension | Versions Supported by ACIS 2024 1.0 |
| ACIS | .sat | R18 – 2024 1.0 |
| CATIA V5 | .CATPart, .CATProduct | V5 R15 – V5–6 R2024 |
| IGES | .igs, .iges | 5.3 |
| STEP | .stp, .step | AP203, AP214, AP242 (Geometry only) |
