Simulink Category: Functions and Tables blocks
Embed Block Equivalent: 2D Map compound block
This block is implemented through the map block. It requires an additional map file. The translator automatically generates the file. However, if arguments for the original block are complicated MATLAB expressions, the original expressions are written to a file that you must convert manually.
