Using the Extern Definition and Extern Function blocks
After you import libraries, you use the Extern Definition block to set up the #include, #define, and instantiation declarations from the Arduino sketch and the Extern Function block to integrate a setup loop in the diagram.
The Embed Common Simulation and Code Generation Tasks Tutorial at Altair Community Documentation includes an example that demonstrates using the Extern blocks with imported Arduino libraries.
