Create an Asset on a Pre-Installed OS
Important: Check the requirements before deploying
the pre-installed OS, as you will first need to create an App (an App is a set
of permissions needed to ensure that the access to data is secure and that the
user is authorized to perform the request).
Under Requirements, click Create an App.
The app should have "cluster" as the scope and the type should be set to "client credentials." The Application Client ID and Secret ID are required in configuring the Image. Be sure to capture and save this information when creating the App.
- Set a name for your Asset and enter a description, if desired.
- Choose the App Client ID from the drop down menu and enter the App Secret ID.
- Choose your fleet ID from the list or create a new one.
Verify that you have completed the appropriate preparation steps (installing
k3s and Ubuntu, etc.) and click Next.
Run the commands that appeared in Altair IoT Studio on the hardware's
shell, simply copy/paste if possible. These commands will allow you to deploy
the Management Server on the Asset and connect to Altair IoT Studio:
When the Asset has successfully established connection
with Altair IoT Studio, the following message will appear. Select the
Next button to continue.
You will be taken then to the Asset's monitoring page. This is where you can see it's operating statistics and deployments.On the header you can find the following options:
- View Thing: Redirect to the Thing in AnythingDB that represents your asset. This Thing is automatically created. More details can be found here.
- Recreate Setup: Recreate the configuration. Note this should only be used if there is no longer a valid edge device.
- API Client: Opens the API Client pane where REST API calls to the Edge Compute Platform running on the Asset can be made. More info can be found here.
- Synced Things: Any Thing created in AnythingDB exists on the cloud only. To use the Thing at the Edge it needs to be synchronized to the Edge. Use this option to do the synchronization. More info can be found here.
