Create Efficient VOV Scripts
If your flows are small, such as a few thousands jobs, you probably do not need to worry much about efficiency of your scripts. If you expect to operate on flows with hundreds of thousands of jobs, then this section can be useful.
While developing a VOV script, it is important to make sure that they do not needlessly make expensive calls that take a lot of vovserver time.
% setenv VOV_SHOW_SERVICE_TIME 1
% vovproject sanity
vovsh(19194) Nov 12 12:36:35 SERVICE_TIME: Service took 2027ms for 137=SanityCheck
vovsh(19194) Nov 12 12:36:35 SERVICE_TIME: Total service time for this client: 2.027sIn this example, vovserver took a bit more than 2 seconds to complete the reply to the request "SanityCheck" (internal code 137). This is normal for SanityCheck, and it is a reason why you do not want to run SanityCheck unless really necessary. Most VOV services you really need should be in the low millisecond range.
% setenv VOV_DEBUG_FLAGS 16 ; ### This has to be 16 to show the RPC codes.Experiments
#!/bin/csh -f
# Try this script and compare the load on the server
# Assume it is called "my_test_script"
set id = `vovsh -x 'FDL_INIT; VovUtils:init; set vovutils(feedback) quiet; puts [J vw hostname]'
vovselect status from jobs where id==$id ; ######## A common mistake
vovselect status from $id
# NC variants
nc info $id | grep Status | awk '{print $2}'
nc list | grep $id | awk '{print $2}' ;;; ## Another horrible yet common mistake
nc getfield $id status ;;; ## BEST way!
####### NOTE: This experiment run with 500,000 jobs in the flow.
% unsetenv VOV_DEBUG_FLAGS
% ./my_test_script
vovsh(9612) Nov 12 15:19:48 SERVICE_TIME: Total service time for this client: 0.000s
vovsh(9617) Nov 12 15:19:48 SERVICE_TIME: Service took 8ms for 307=CreateQuery select:fieldname from:jobs
vovsh(9617) Nov 12 15:19:48 SERVICE_TIME: Service took 707ms for 307=CreateQuery select:status from:jobs where:id==002233767
INVALID
vovsh(9617) Nov 12 15:19:48 SERVICE_TIME: Total service time for this client: 0.715s
INVALID
vovsh(9671) Nov 12 15:19:49 SERVICE_TIME: Total service time for this client: 0.000s
vovsh(9698) Nov 12 15:19:49 SERVICE_TIME: Service took 1ms for 208=GetInfoMap project
vovsh(9698) Nov 12 15:19:49 SERVICE_TIME: Total service time for this client: 0.001s
Idle
vovsh(9724) Nov 12 15:19:52 SERVICE_TIME: Service took 2607ms for 296=ListElementsEnh id:000001041 format:@ID@ @STATUSNC:9@ @PRIORITYPP:6@ @HOST:14@ @COMMAND:40@ range:0--1
vovsh(9724) Nov 12 15:19:54 SERVICE_TIME: Total service time for this client: 2.607s
Idle
INVALID
vovsh(9928) Nov 12 15:19:55 SERVICE_TIME: Total service time for this client: 0.000s
