Create a Quick Report
Generate an analysis report using the saved settings. You can export the report as a .ppt or .pdf file.
First, run a structural analysis.
First, run a fluids analysis.
First, run a motion analysis.
First run an analysis.
First, run an analysis.
First, run a foaming ananlysis
To customize the report settings, see Customize the Report Settings and Create a Report.
  1. On the Structures ribbon, select Quick Report.
    Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools.
  2. On the Fluids ribbon, select Quick Report.
  3. On the Motion ribbon, select Quick Report.
  4. On the Casting ribbon, select Quick Report.
  5. On the Molding ribbon, select Quick Report.
  6. On the Foaming ribbon, select Quick Report.
  7. Browse to the location where you want to save the file. The default location is C:\Documents\Altair\reports.
    Note: To change the location:
    1. From the File menu, select the Preferences button.
    2. Under Category, select Report.
    3. Change the Save Settings. For more information, see Preferences: Report.
  8. Enter the file name.
  9. Choose a file format:
    • PPTX
    • PDF
  10. Click Save.
