Gaussian Pulse (Normal Distribution)
Define a Gaussian time pulse with a normal distribution.
Figure 1. Define a Gaussian time pulse with a normal distribution.
Time axis unit
Specify the unit to be used for the time axis.
Total signal duration ( s d )
The total length of the signal in the specified units.
Amplitude ( u 0 )
The amplitude of the time signal.
Pulse delay ( t 0 )
The pulse delay is the time until the peak of the time signal envelope.
Pulse width ( p w )
This is the half-amplitude pulse width of the signal. The pulse width is the total length of time that the signal is above 50% of its peak value ( u 0 ).
Number of samples
The number of samples taken from the signal’s analytical equation.
u ( t ) = { 0 for  t ≤ t 0 u 0 ( e − t − t 0 τ 1 − e − t − t 0 τ 2 ) for  t > t 0
The Fourier transform is as follows:
U ( f ) = u 0 ( τ 1 1 + j 2 π f τ 1 − τ 2 1 + j 2 π f τ 2 ) e − j 2 π f t 0
