Artificial Viscosity
As usual in SPH 1 implementations, viscosity is rather an inter-particles pressure than a bulk pressure. It was shown that the use of Equation 1 and Equation 2 generates a substantial amount of entropy in regions of strong shear even if there is no compression.
πij=qbci+cj2μij+qαμ2ij(ρi+ρj)2
with
μij=dij(vivj)(XiXj)XiXj2+εd2ij
Where, Xi (resp. Xj ) indicates the position of particle I (resp. j ) and ci (resp cj ) is the sound speed at location i (resp. j ), and qa and qb are constants. This leads us to introduce Equation 3 and Equation 4. 2 The artificial viscosity is decreased in regions where vorticity is high with respect to velocity divergence.
with
μij=dij(vivj)(XiXj)XiXj2+εd2ij(fi+fj)2,fk=v|kv|k+×v|k+εckdk
Default values for qa and qb are respectively set to 2 and 1.
1
Monaghan J.J., Smoothed Particle Hydrodynamics, Annu.Rev.Astron.Astro-phys; Vol. 30; pp. 543-574, 1992.
2
Balsara D.S., Von Neumann Stability Analysis of Smoothed Particle Hydrodynamics Suggestions for Optimal Algorithms, Journal of Computational Physics, Vol. 121, pp. 357-372, 1995.
