One Degree of Freedom Spring Elements (TYPE4)
- Spring only
- Dashpot (damper) only
- Spring and dashpot in parallel
No material data card is required for spring elements. However, the stiffness k and equivalent viscous damping coefficient c are required. The mass m is required if there is any spring translation.
- Linear Stiffness
- Nonlinear Stiffness
- Nonlinear Elasto-Plastic Stiffness
- Linear
- Nonlinear
A spring may also have zero length. However, a one DOF spring must have 2 nodes.
Time Step
The time of a spring element depends on the values of stiffness, damping and mass.
For a spring only element:
For a dashpot only element:
For a parallel spring and dashpot element:
The critical time step ensures that the stability of the explicit time integration is maintained, but it does not ensure high accuracy of spring vibration behavior. Only two time steps are required during one vibration period of a free spring to keep stability. However, if true sinusoidal reproduction is desired, the time step should be reduced by a factor of at least 5.
If the spring is used to connect the two parts, the spring vibration period increases and the default spring time step ensures stability and accuracy.
Linear Spring
Function number defining f(δ) .
N1=0
The stability condition is given by Equation 3:
Nonlinear Elastic Spring
Hardening flag
The stability criterion is the same as for the linear spring, but rather than being constant, the stiffness is displacement dependent:
Where,
Nonlinear Elasto-plastic Spring: Isotropic Hardening
Nonlinear Elasto-plastic Spring: Decoupled Hardening
Nonlinear Elasto-plastic Spring: Kinematic Hardening
Nonlinear Elasto-plastic Spring: Nonlinear Unloading
The hardening flag is set to 5 in this case and f(δ) and f2(δmax) (maximum yield force and residual deformation, respectively) are defined by a function. Uncoupled hardening in compression and tensile behavior with nonlinear unloading:
Nonlinear Dashpot
- Mass, M .
- A function defining the change in force with respect to the spring displacement. This must
be equal to unity:
f(l−l0)=1
- A function defining the change in force with spring displacement rate,
g(dl/dt)
- The hardening flag in the input must be set to zero.
The relationship between force and spring displacement and displacement rate is:
The stability condition for a nonlinear dashpot is given by:
Where,
Nonlinear Viscoelastic Spring
- Mass, M
- Equivalent viscous damping coefficient C
f(l−l0)
g(dl/dt)
The hardening flag in the input must be set to equal zero. The force relationship is given by:
The stability condition is given by:
Where,
