/SKEW/FIX
Block Format Keyword Describes the fixed skew frames.
/SKEW/FIX/skew_ID/unit_ID | |||||||||
skew_title | |||||||||
Ox | Oy | Oz | |||||||
X1 | Y1 | Z1 | |||||||
X2 | Y2 | Z2 |
Definition
skew_ID | Skew identifier This ID must be different from all frame (/FRAME/FIX) identifiers (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
skew_title | Skew title (Character, maximum 100 characters) |
Ox | X coordinate of skew
origin O' (Real) |
[m] |
Oy | Y coordinate of skew
origin O' (Real) |
[m] |
Oz | Z coordinate of skew
origin O' (Real) |
[m] |
X1 | X component of skew
Y'
axis (Real) |
Y1 | Y component of skew
Y'
axis (Real) |
Z1 | Z component of skew
Y'
axis (Real) |
X2 | X component of skew
Z'
axis (Real) |
Y2 | Y component of skew
Z'
axis (Real) |
Z2 | Z component of skew
Z'
axis (Real) |
- For fixed skews, the skew system is fixed and is defined by Y' and Z' . Vectors of arbitrary length may be given.
- For a fixed skew, inputs are
Y'
axis and
Z'
axis, but
X′
axis is computed as: X′=Y'ΛZ'
Y' is recomputed as:
Y″ - The new fixed skew is defined by , and .
- The skew origin O' is useful when
defining some condition with respect to the skew in cylindrical coordinate system.
