/SENSOR/VEL
Block Format Keyword Describes the sensor activated when the velocity of the chosen node reaches the prescribed limit value.
/SENSOR/VEL/sens_ID/unit_ID | |||||||||
sens_title | |||||||||
Tdelay | |||||||||
node_ID | Vmax | Fcut |
Definition
sens_ID | Sensor
identifier. (Integer, maximum 10 digits) |
unit_ID | Optional unit
sens_title | Sensor
title. (Character, maximum 100 characters) |
Tdelay | Time delay. Default = 0.0 (Real) |
[s] |
node_ID | Reference node
identifier. (Integer) |
Vmax | Max velocity.
(Real) |
[ms] |
Fcut | Filtering frequency of
low pass filter for nodal velocity. (Real) |
[Hz] |
- The sensor is activated when nodal velocity is greater than Vmax and after the time Tdelay.
