Starter and Engine Setup
The Runname_nnnn.sta is written by entering the following keyword in the Radioss Engine files.
This must be set in /STATE/DT in the Engine
file.
/STATE/DT
Tstart Tfreq
Part_ID1 ... Part_IDN
STATE files are written with a time frequency Tfreq, the first file being written at time Tstart.
As of Version 11.0, /STATE/STR_FILE can also be used in Engine file to write /INISHE, /INISH3 and /INIBRI in a separate file, which can be compressed (using GZIP).
This file can be read in Starter with the same keyword /STATE/STR_FILE (Runname_run#.sta File).
Corresponding Starter and Engine Keywords
Starter Keywords | Engine Keywords | Comment |
/INIBEAM/AUX | /STATE/BEAM/AUX | Writes Auxiliary variable of beam into each state file. |
/INIBEAM/FULL | /STATE/BEAM/FULL | Writes force, moment, energy and so on for beam into each state file. |
/INIBRI/AUX | /STATE/BRICK/AUX/FULL | Writes Auxiliary variable of solid into each state file. |
/INIBRI/STRA_F | /STATE/BRICK/STRAIN/FULL | Writes Strain full of solid into each state file. |
/INIBRI/STRA_FGLO | /STATE/BRICK/STRAIN/GLOBFULL | Writes Strain state for solid in global system into each state file. |
/INIBRI/STRS_F | /STATE/BRICK/STRES/FULL | Writes Stress full of solid into each state file. |
/INIBRI/STRS_FGLO | /STATE/BRICK/STRES/GLOBFULL | Writes Stress state for solid in global system into each state file. |
/INIBRI/FAIL | /STATE/BRICK/FAIL | Writes failure criteria of solid to each state file. |
/INIBRI/ORTHO | /STATE/BRICK/ORTHO | Writes orthotropy direction of orthotropic solid to each state file. |
/INISHE/AUX or /INISH3/AUX | /STATE/SHELL/AUX/FULL | Writes Auxiliary variable of shell into each state file. |
/INISHE/EPSP_F or /INISH3/EPSP_F | /STATE/SHELL/EPSP/FULL | Writes plastic strain in an integration point of shell element into each state file. |
/INISHE/FAIL or /INISH3/FAIL | /STATE/SHELL/FAIL | Writes failure criteria of shell element to each state file. |
/INISHE/ORTH_LOC or /INISH3/ORTH_LOC | /STATE/SHELL/ORTHL | Writes the orthotropy direction of each shell in each state file. |
/INISHE/STRA_F or /INISH3/STRA_F | /STATE/SHELL/STRAIN/FULL | Writes Strain full of shell into each state file. |
/INISHE/STRS_F/GLOB or /INISH3/STRS_F/GLOB | /STATE/SHELL/STRESS/FULL | Writes Stress full of shell into each state file. |
/INISPRI/FULL | /STATE/SPRING/FULL | Writes stress state of spring into each state file. |
/INITRUSS/FULL | /STATE/TRUSS/FULL | Writes force, energy and so on for truss into each state file. |
/INITEMP | /STATE/NODE/TEMP | Writes temperature for node into each state file. |
/STATE/LSENSOR | Write state file due to sensor activation. |
▸Runname_0001.rad Example
▸Runname_0001.sta File Example
- The first lines of an element are always written, even if there is no element of that type. In such a case, a line is left blank below the option.
- First
line is always
#RADIOSS Runname_nnnn.sta
according to the /IOFLAG keyword. - The
Runname_nnnn.sta file always finishes with
#ENDDATA
