/PROP/TYPE34 (SPH)
Block Format Keyword Describes SPH property set.
/PROP/TYPE34/prop_ID or /PROP/SPH/prop_ID
prop_title
mp β α MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdegaaa@3792@ α cs skew_ID h_ID
order h ξstab
Definition
prop_ID Property identifier.
(Integer, maximum 10 digits)
prop_title Property title.
mp Mass of the particles.
(Real)
[ kg ]
β Quadratic bulk viscosity.
Default = 2.0 (Real)
α MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdegaaa@3792@ Linear bulk viscosity.
Default = 1.0 (Real)
α cs Conservative smoothing coefficient.
(Real)
skew_ID Skew identifier to define the initial orthotropic directions in the case of skew_ID ≠ 0 (means property is orthotropic).
(Integer)
h_ID Smoothing length change based on volume. 5
= 0 (Default)
3D expansion of h.
= 1
1D expansion of h.
(Integer)
order SPH correction order.
= -1
Means no correction at all.
= 0 (Default)
Means order 0 correction.
= 1
Means correction up to order 1 - not allowed for SPMD parallel version.
(Integer)
h Smoothing length.
Default: see 1 (Real)
[ m ]
ξ stab Coefficient for solving tensile instability.
Default = 0.0 (Real)
Example (Bird Strike)
#RADIOSS STARTER
/PROP/TYPE34/3000001
BIRD_sphv1 (unit kg_mm_ms) data from Example 49 - Bird Strike on Windshield
#                 mp                beta               alpha            alpha_cs   skew_ID      h_ID
         1.725149E-4               2E-30               1E-30                   0         0         0
#    order                   h             xi_stab
         0               6.286                   0
#ENDDATA
  1. Default value for smoothing length is set as:
    h = ( m p 2 ρ ) 1 3
    which corresponds to the inter-particles distance when the particles distribution is hexagonal compact.
    For face centered cubic and hexagonal compact net distribution, the recommended smoothing length h MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiAaaaa@36E4@ is the pitch entered when generating the SPH particles.
  2. The kinetic energy absorbed by conservative smoothing of velocities is output as hourglass energy into /TH/PART files.
  3. If ξ stab is not equal to zero, an artificial stress is added to solve the tensile instability, proposed by:
    J.J. Monaghan, SPH without a Tensile Instability, Journal of Computational Physics, vol. 159, pp. 290-311, 2000
    A value of ξ s t a b = 0.3 MathType@MTEF@5@5@+= feaahqart1ev3aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacqaH+oaEpaWaaSbaaSqaa8qacaWGZbGaamiDaiaadggacaWGIbaa paqabaGccqGH9aqpcaaIWaGaaiOlaiaaiodaaaa@3F28@ is recommended.
  4. If the sphpart_ID is used with Sol2SPH option, (in /PROP/SOLID), h MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiAaaaa@36E4@ must be input. The mass of the particle can be 0.0 (it is automatically calculated by Radioss). A good value of the smoothing length is:
    h = 1.5 l N d i r MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiAaiabg2 da9maalaaabaGaaGymaiaac6cacaaI1aGaamiBaaqaaiaad6eacaWG KbGaamyAaiaadkhaaaaaaa@3EB8@
    Where,
    h MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiBaaaa@36E8@
    Smoothing length
    l MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiBaaaa@36E8@
    Size of the brick elements
    N d i r MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOtaiaads gacaWGPbGaamOCaaaa@3998@
    Number of particle per direction for each solid element
  5. The smoothing length on each particle is updated during the computation according to the change in the volume.
    If h_ID=0, the change in the volume is based on three dimensions:
    d h h = 1 3 d V o l V o l = 1 3 d i v V d t MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaaSaaaeaaca WGKbGaamiAaaqaaiaadIgaaaGaeyypa0ZaaSaaaeaacaaIXaaabaGa aG4maaaadaWcaaqaaiaadsgacaWGwbGaam4BaiaadYgaaeaacaWGwb Gaam4BaiaadYgaaaGaeyypa0ZaaSaaaeaacaaIXaaabaGaaG4maaaa caWGKbGaamyAaiaadAhaceWGwbGbaSaacaWGKbGaamiDaaaa@4A00@
    If h_ID=1, the change in the volume is based on one dimension:
    d h h = d V o l V o l = d i v V d t MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaaSaaaeaaca WGKbGaamiAaaqaaiaadIgaaaGaeyypa0ZaaSaaaeaacaWGKbGaamOv aiaad+gacaWGSbaabaGaamOvaiaad+gacaWGSbaaaiabg2da9iaads gacaWGPbGaamODaiqadAfagaWcaiaadsgacaWG0baaaa@46F0@
