/MAT/LAW92
Block Format Keyword This law describes the Arruda-Boyce material model, which can be used to model hyperelastic behavior.
A stress versus strain curve can be defined as an input function in order to determine the material parameters by fitting this curve. This law is only compatible with solid elements.
/MAT/LAW92/mat_ID/unit_ID
mat_title
ρi
Parameter input
μ D λm
Function input
Itype fct_ID ν Fscale
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
mat_title Material title.
ρi Initial density.
(Real)
[kgm3]
μ Shear modulus.
Used only if fct_ID is not defined.
(Real)
[Pa]
D Material parameter.
If null, D is automatically computed from μ , λm and ν =0.495. 2
(Real)
[1Pa]
λm The limit of stretch.
Default = 7.0 (Real)
Itype Test data type (stress strain curve).
= 1 (Default)
Uniaxial data test
= 2
Equibiaxial data test
= 3
Planar data test
(Integer)
fct_ID Function identifier defining engineer stress versus engineer strain.
(Integer)
ν Poisson's ratio.
Used only if fct_ID is defined.
Default = 0.495 (Real)
Fscale Scale factor for ordinate (stress) in function fct_ID.
Default = 1.0 (Real)
[Pa]
Example (Rubber with Parameter Input)
Example (Rubber with Function Input)
  1. The Arruda-Boyce energy density.
    W=μ5i=1ci(λm)2i2(ˉIi13i)+1D(J212ln(J))
    With
    c1=12,c2=120,c3=111050,c4=197000,c5=519673750
    and
    ˉI1=ˉλ21+ˉλ22+ˉλ23
    with ˉλk=J1/3λJ=λ1λ2λ3
    The Cauchy stress is computed as:
    σi=λiJWλi
  2. If the stress strain curve, fct_ID is not defined, the material parameters in line 3, μ , D and λm must be defined and the line 4 input is not used.
    Ground shear modulus is computed as:
    μ0=μ(1+35(1λ2m)+99175(1λ4m)+513875(1λ6m)+4203967375(1λ8m))
    If D is not defined, the bulk modulus is calculated as:
    K=2(1+υ)μ03(12υ)
    Where, υ=0.495 and D=2K .
    If D is defined, the formula should be K=2D , and the Poisson ratio is updated with υ=3K2μ03 .
    Note: For positive values of shear modulus, μ , and Limit of stretch, λm , this model is always stable.
  3. If the stress strain curve, fct_ID, is defined then the line 3 input parameters μ , D and λm are ignored and are automatically identified by fitting of the provided stress versus strain curve.
    A nonlinear least squares algorithm is used to fit the Arruda-Boyce parameters. The model is fully incompressible in fitting the Arruda-Boyce constants to the test data, except in the volumetric test.
    E=ndatak=1(NtestkNthkNtestk)2
    Where E is relative error. The material constants are obtained using a least-squares-fit procedure to minimize the relative error between the theoretical nominal stress and given experimental data.
    λ1=λ2=λandλ3=λ2withλ=1+ε
    Where, Ntestk is a stress value from the test data and Nthi is the theoretical nominal stress given by for each engineer strain i.
    Nthk=Wλk
    The nominal stress is computed for each mode assuming the full incompressibility:
    J=λ1λ2λ3=1
    • Uniaxial Mode:
      λ1=λandλ2=λ3=λ12withλ=1+ε
      So
      Nth=Wλ=2μ(λλ2)5i=1ici(λm)2i2ˉIi11withˉI1=λ2+2λ
    • Equibiaxial Mode:
      So
      Nth=Wλ=2μ(λλ5)5i=1ici(λm)2i2ˉIi11withˉI1=2λ2+1λ4
    • Planar (Shear Mode):
      λ1=λ,λ3=1andλ2=λ1withλ=1+ε
      So
      Nth=Wλ=2μ(λλ3)5i=1ici(λm)2i2ˉIi11withˉI1=λ2+1+λ2
  4. /VISC/PRONY must be used with LAW92 to include viscous effects.
