/MAT/LAW54 (PREDIT)
Block Format Keyword This law describes the predit material. This material law is only used with /PROP/TYPE36 (PREDIT).
/MAT/LAW54/mat_ID/unit_ID or /MAT/PREDIT/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
ρi | |||||||||
E | ν | ||||||||
fct_ID | A | B | N | Fscaleyld | |||||
AY | AZ | BY | BZ | CX | |||||
Dc | RC | εmax |
Definition
mat_ID | Material identifier (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
mat_title | Material title (Character, maximum 100 characters) |
ρi | Initial density (Real) |
[kgm3] |
E | Young's modulus (Real) |
[Pa] |
ν | Poisson's ratio (Real) |
fct_ID | Hardening parameter function identifier (optional).
(Integer) |
A | Hardening parameter yield coefficient
A. (Real) |
B | Hardening parameter yield coefficient
B. (Real) |
N | Hardening parameter yield coefficient
N. (Real) |
Fscaleyld | Yield function scale factor. Default = 1.0 (Real) |
[Pa] |
AY | Y
shear coefficient of component
yield. (Real) |
AZ | Z
yield. (Real) |
BY | Y
moment coefficient of component
yield. (Real) |
BZ | Z
yield. (Real) |
CX | X
torsion coefficient of component
yield. (Real) |
Dc | Critical damage (Real) |
RC | Critical failure (Real) |
εmax | Damage strain limit (Real) |
▸Example (Steel)
- Scale factor is only used for fct_ID; otherwise /MAT/LAW36 (PLAS_TAB) is used.
