/MAT/LAW108 (SPR_GENE)
Block Format Keyword This spring material works with six independent modes of deformation and accounts for nonlinear stiffness, damping and different unloading.
Deformation, force and energy-based failure criteria are available. The general spring material is often used to model a joint connection between two parts. This material must be assigned to a /PART that references the spring property /PROP/TYPE23 (SPR_MAT).
/MAT/LAW108/mat_ID/unit_ID or /MAT/SPR_GENE/mat_ID/unit_ID
mat_title
ρ
Ifail Iequil Ifail2
Loading index=1: Translation in X
K1 C1 A1 B1 D1
fct_ID11 H1 fct_ID21 fct_ID31 fct_ID41 δ min 1 δ max 2
F1 E1 Ascale1 Hscale1
Loading index=2: Translation in Y
K2 C2 A2 B2 D2
fct_ID12 H2 fct_ID22 fct_ID32 fct_ID42 δ min 2 δ max 2
F2 E2 Ascale2 Hscale2
Loading index=3: Translation in Z
K3 C3 A3 B3 D3
fct_ID13 H3 fct_ID23 fct_ID33 fct_ID43 δ min 3 δ max 3
F3 E3 Ascale3 Hscale3
Loading index=4: Rotation in X
K4 C4 A4 B4 D4
fct_ID14 H4 fct_ID24 fct_ID34 fct_ID44 θ min 4 θ max 4
F4 E4 Ascale4 Hscale4
Loading index=5: Rotation in Y
K5 C5 A5 B5 D5
fct_ID15 H5 fct_ID25 fct_ID35 fct_ID45 θ min 5 θ max 5
F5 E5 Ascale5 Hscale5
Loading index=6: Rotation in Z
K6 C6 A6 B6 D6
fct_ID16 H6 fct_ID26 fct_ID36 fct_ID46 θ min 6 θ max 6
F6 E6 Ascale6 Hscale6
Filtering force
Fsmooth Fcut
Definition
prop_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
prop_title Material title.
ρ Density.
(Real)
[ kg m 3 ]
Ifail Failure criteria.
= 0
Uni-directional criteria.
= 1
Multi-directional criteria.
(Integer)
Iequil Equilibrium flag. 5 6
= 0
No equilibrium.
= 1
Force and moment equilibrium.
(Integer)
Ifail2 Failure model flag.
= 0 (Default)
Displacement and rotation criteria.
= 1
Force criteria (moment criteria).
= 3
Internal energy criteria.
(Integer)
Ki If f c t _ I D   1 i = 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGMbGaam 4yaiaadshacaGGFbGaamysaiaadseadaWgaaWcbaGaaeiiaiaaigda caWGPbaabeaakiabg2da9iaaicdaaaa@40F0@ : Linear loading and unloading stiffness.
If f c t _ I D   1 i ≠ 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqGqFfpeea0xe9vq=Jb9 vqpeea0xd9q8qiYRWxGi6xij=hbba9q8aq0=yq=He9q8qiLsFr0=vr 0=vr0db8meaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGMbGaam 4yaiaadshacaGGFbGaamysaiaadseadaWgaaWcbaGaaeiiaiaaigda caWGPbaabeaakiabgcMi5kaaicdaaaa@41B1@ : Only used as unloading stiffness for elasto-plastic springs.
i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =1, 2, 3 are translation DOF
i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =4, 5, 6 are rotation DOF
Comment 7
(Real)
[ N m ] for i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =1, 2, 3
[ Nm rad ] for i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =4, 5, 6
Ci Damping.
(Real)
[ N s m ] for i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =1, 2, 3
[ Nms rad ] for i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =4, 5, 6
Ai Nonlinear stiffness function scale factor.
Default = 1.0 (Real)
[ N ] for i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =1, 2, 3
[ Nm ] for i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =4, 5, 6
Bi Logarithmic rate effects scale factor.
Default = 0.0 (Real)
Di Logarithmic rate effects scale factor.
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@ for i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =1, 2, 3
[ rad s ] for i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =4, 5, 6
fct_ID1i Function identifier defining nonlinear stiffness f ( ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGMbWaae WaaeaaaiaawIcacaGLPaaaaaa@38D3@ . 7
= 0
Linear spring with stiffness K
If H1 = 4: Function identifier defining upper yield curve.
If H1 = 8: Function is mandatory and defines the force or moment versus spring length.
(Integer)
Hi Nonlinear Spring Hardening flag for nonlinear spring.
=0
Elastic spring.
=1
Nonlinear elastic plastic spring with isotropic hardening.
=2
Nonlinear elastic plastic spring with uncoupled hardening.
=4
Nonlinear elastic plastic spring with kinematic hardening.
=5
Nonlinear elastic plastic spring with nonlinear unloading.
=6
Nonlinear elastic plastic spring with isotropic hardening and nonlinear unloading.
=7
Nonlinear elastic plastic spring with elastic hysteresis.
(Integer)
fct_ID2i Function identifier defining force or moment as a function of spring velocity g ( ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGNbWaae WaaeaaaiaawIcacaGLPaaaaaa@38D5@ .
(Integer)
fct_ID3i Function identifier.
If H1 = 4: Defines lower yield curve.
If H1 = 5: Defines residual displacement or rotation versus maximum displacement or rotation.
If H1= 6: Defines nonlinear unloading curve.
If H1= 7: Defines nonlinear unloading curve.
(Integer)
fct_ID4i Function identifier for nonlinear damping h ( ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGObWaae WaaeaaaiaawIcacaGLPaaaaaa@38D5@ .
(Integer)
δ min i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH0oazda qhaaWcbaGaciyBaiaacMgacaGGUbaabaGaamyAaaaaaaa@3BF0@ Negative translation failure limit.
Default = -1030 (Real)
If Ifail2=0: Failure displacement [ m ]
If Ifail2=1: Failure force [ N ]
If Ifail2=2: Failure internal energy [ J ]
θ min i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH4oqCda qhaaWcbaGaciyBaiaacMgacaGGUbaabaGaamyAaaaaaaa@3C01@ Negative rotational failure limit.
If Ifail2=0: Failure rotation [ rad ]
If Ifail2=1: Failure moment [ N ⋅ m ] MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaaci GGobGaeyyXICTaciyBaaGaay5waiaaw2faaaaa@3BFA@
δ max i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH0oazda qhaaWcbaGaciyBaiaacggacaGG4baabaGaamyAaaaaaaa@3BF2@ Positive transition failure limit.
Default = 1030 (Real)
θ max i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH4oqCda qhaaWcbaGaciyBaiaacMgacaGGUbaabaGaamyAaaaaaaa@3C01@ Positive rotational failure limit.
Fi Abscissa scale factor for the damping functions for the g MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E2@ and h MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E2@ .
Ei Ordinate scale factor for the damping function g MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E2@ .
(Real)
Ascalei Abscissa scale factor for the stiffness function f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E2@ .
[ m ] for i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =1, 2, 3
[ rad ] for i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =4, 5, 6
Hscalei Ordinate Scale factor for the damping function h MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E2@ .
Fsmooth Smooth strain rate flag.
=0(Default)
Strain rate smoothing is inactive.
=1
Strain rate smoothing is active.
(Integer)
Fcut Strain rate cutting frequency.
[Hz]
Example (Spotweld - No Rupture)
#RADIOSS STARTER
#-  1. LOCAL_UNIT_SYSTEm:
/UNIT/2
units for material and property
                  kg                  mm                  ms
/PROP/TYPE23/6680004/2
SPOTWELD_NO_RUPTURE
#    Imass                          Area             Inertia   skew_ID   sens_ID    Isflag
         2                          8E+3                .002         0         0         0
/MAT/LAW108/6680004/2
TYPE8
#            Density
                1E-6
#    Ifail    Iequil    Ifail2
                   0
#              KTens               CTens               ATens               BTens               DTens
                 1.8                   0                   0                   0                   0
#  fct_ID1     HTens   fct_ID2   fct_ID3   fct_ID4                 delta_minTens       delta_maxTens
                   0         0         0         0                             0                   0
#                  F                   E              Ascale             Hscalex
                   0                   0                   0                   0
                  .3                   0                   0                   0                   0
                   0         0         0         0                             0                   0
                   0                   0                   0                   0
                 1.8                   0                   0                   0                   0
                   0         0         0         0                             0                   0
                   0                   0                   0                   0
#                  K                   C                   A                   B                   D
    114.649681528662                   0                   0                   0                   0
#       N1         H        N2        N3        N4                     theta_min           theta_max
                   0         0         0         0                             0                   0
                   0                   0                   0                   0
#                  K                   C                   A                   B                   D
                   0         0         0         0                             0                   0
                   0                   0                   0                   0
#                  K                   C                   A                   B                   D
                   0         0         0         0                             0                   0
#   ISTRAT             ASTRAT
         0                   0
#enddata
  1. When used with /PROP/TYPE23 (SPR_MAT), this material law has the same behavior as spring property /PROP/TYPE8 (SPR_GENE); except that in this material the mass is calculated from the density and volume, or density, area and length.
  2. Inputs repeated for each degree of freedom (DOF) i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ are defined with the following directions:
    • i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =1: tension/compression
    • i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =2: shear xy
    • i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =3: shear xz
    • i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =4: torsion
    • i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =5: bending y
    • i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E4@ =6: bending z
  3. This spring should only be used when the spring has zero initial length or when one of the spring nodes is constrained in all directions. For other situations, the equilibrium is insured for forces, but not for moments. Thus, the moment calculation can be incorrect. If the initial spring length is not zero, use /PROP/TYPE13 (SPR_BEAM) or /MAT/LAW113 (SPR_BEAM).
  4. The spring has six DOF δ 1 , δ 2 , δ 3 , θ 4 , θ 5 , θ 6 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH0oazda ahaaWcbeqaaiaaigdaaaGccaGGSaGaeqiTdq2aaWbaaSqabeaacaaI YaaaaOGaaiilaiabes7aKnaaCaaaleqabaGaaG4maaaakiaacYcacq aH4oqCdaahaaWcbeqaaiaaisdaaaGccaGGSaGaeqiUde3aaWbaaSqa beaacaaI1aaaaOGaaiilaiabeI7aXnaaCaaaleqabaGaaGOnaaaaaa a@4991@ computed in a local coordinate system. The local system can be defined for each element using /SPRING Skew_ID. If Skew_ID is not defined for each element, the local system defined in the /PROP/TYPE23 (SPR_MAT) Skew_ID is used. If a system is not defined in the element or property, then the global system is used.
  5. The sign (tension or compression) of the spring force depends on the relative displacement of Node N2 with respect to Node N1. If the movement of node N2 relative to node N1 is in the positive direction of the spring system, then the spring is in tension. If the movement of node N2 relative to node N1 is in the negative direction of the spring system, then the spring is in compression.
  6. If Iequil = 0 (no equilibrium), then:
    f ( θ ) = M 2 y = − M 1 y
    M 2 y MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbWaaS baaSqaaiaaikdacaWG5baabeaaaaa@3916@ is moment in Y by N2
    M 1 y MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbWaaS baaSqaaiaaikdacaWG5baabeaaaaa@3916@ is moment in Y by N1
    If Iequil = 1 (force and moment equilibrium), then:
    − M 1 y ≠ M 2 y         − M 1 z ≠ M 2 z
    f ( θ ) = M 2 y − M 1 y 2
    M 2 z MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbWaaS baaSqaaiaaikdacaWG5baabeaaaaa@3916@ is moment in Z by N2
    M 1 z MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbWaaS baaSqaaiaaikdacaWG5baabeaaaaa@3916@ is moment in Z by N1
  7. Force and moment computation.
    • δ is a translational DOF, the force in direction δ is computed as:
      F ( δ ) = f ( δ i A s c a l e i ) [ A i + B i ln | δ ˙ i D i | + E i g ( δ ˙ i F i ) ] + C i δ ˙ i + H s c a l e i h ( δ ˙ i F i ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGgbWaae WaaeaacqaH0oazaiaawIcacaGLPaaacqGH9aqpciGGMbWaaeWaaeaa daWcaaqaaiabes7aKnaaCaaaleqabaGaamyAaaaaaOqaaiaadgeaca WGZbGaam4yaiaadggacaWGSbGaamyzamaaBaaaleaacaWGPbaabeaa aaaakiaawIcacaGLPaaadaWadaqaaiaadgeadaWgaaWcbaGaamyAaa qabaGccqGHRaWkcaWGcbWaaSbaaSqaaiaadMgaaeqaaOGaciiBaiaa c6gadaabdaqaamaalaaabaGafqiTdqMbaiaadaahaaWcbeqaaiaadM gaaaaakeaacaWGebWaaSbaaSqaaiaadMgaaeqaaaaaaOGaay5bSlaa wIa7aiabgUcaRiaadweadaWgaaWcbaGaamyAaaqabaGcciGGNbWaae WaaeaadaWcaaqaaiqbes7aKzaacaWaaWbaaSqabeaacaWGPbaaaaGc baGaamOramaaBaaaleaacaWGPbaabeaaaaaakiaawIcacaGLPaaaai aawUfacaGLDbaacqGHRaWkcaWGdbWaaSbaaSqaaiaadMgaaeqaaOGa fqiTdqMbaiaadaahaaWcbeqaaiaadMgaaaGccqGHRaWkcaWGibGaam 4CaiaadogacaWGHbGaamiBaiaadwgadaWgaaWcbaGaamyAaaqabaGc ciGGObWaaeWaaeaadaWcaaqaaiqbes7aKzaacaWaaWbaaSqabeaaca WGPbaaaaGcbaGaamOramaaBaaaleaacaWGPbaabeaaaaaakiaawIca caGLPaaaaaa@762D@ with i =1,2,3
    • θ is a rotational DOF, the moment is computed as:
      M ( θ ) = f ( θ i A s c a l e i ) [ A i + B i ln | θ ˙ i D i | + E i g ( θ ˙ i F i ) ] + C i θ ˙ i + H s c a l e i h ( θ ˙ i F i ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGnbWaae WaaeaacqaH4oqCaiaawIcacaGLPaaacqGH9aqpciGGMbWaaeWaaeaa daWcaaqaaiabeI7aXnaaCaaaleqabaGaamyAaaaaaOqaaiaadgeaca WGZbGaam4yaiaadggacaWGSbGaamyzamaaBaaaleaacaWGPbaabeaa aaaakiaawIcacaGLPaaadaWadaqaaiaadgeadaWgaaWcbaGaamyAaa qabaGccqGHRaWkcaWGcbWaaSbaaSqaaiaadMgaaeqaaOGaciiBaiaa c6gadaabdaqaamaalaaabaGafqiUdeNbaiaadaahaaWcbeqaaiaadM gaaaaakeaacaWGebWaaSbaaSqaaiaadMgaaeqaaaaaaOGaay5bSlaa wIa7aiabgUcaRiaadweadaWgaaWcbaGaamyAaaqabaGcciGGNbWaae WaaeaadaWcaaqaaiqbeI7aXzaacaWaaWbaaSqabeaacaWGPbaaaaGc baGaamOramaaBaaaleaacaWGPbaabeaaaaaakiaawIcacaGLPaaaai aawUfacaGLDbaacqGHRaWkcaWGdbWaaSbaaSqaaiaadMgaaeqaaOGa fqiUdeNbaiaadaahaaWcbeqaaiaadMgaaaGccqGHRaWkcaWGibGaam 4CaiaadogacaWGHbGaamiBaiaadwgadaWgaaWcbaGaamyAaaqabaGc ciGGObWaaeWaaeaadaWcaaqaaiqbeI7aXzaacaWaaWbaaSqabeaaca WGPbaaaaGcbaGaamOramaaBaaaleaacaWGPbaabeaaaaaakiaawIca caGLPaaaaaa@769A@ with i =4,5,6
      Where,
      • δ i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH0oazda ahaaWcbeqaaiaadMgaaaaaaa@391E@ (with − l 0 < δ i < + ∞ MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqGHsislca WGSbWaaSbaaSqaaiaaicdaaeqaaOGaeyipaWJaeqiTdq2aaWbaaSqa beaacaWGPbaaaOGaeyipaWJaey4kaSIaeyOhIukaaa@4051@ ) is the difference between the current length l MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGSbaaaa@374F@ and the initial length l 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGSbWaaS baaSqaaiaaicdaaeqaaaaa@3835@ of the spring element for corresponding translational DOF.
      • θ i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacqaH4oqCda ahaaWcbeqaaiaadMgaaaaaaa@392F@ is the relative angle for corresponding rotational DOF in radians.
      • For linear springs, f δ ,     g δ ˙ ,   h δ ˙ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGMbWaae WaaeaacqaH0oazaiaawIcacaGLPaaacaGGSaGaaGPaVlaaysW7ciGG NbWaaeWaaeaacuaH0oazgaGaaaGaayjkaiaawMcaaiaacYcacaaMe8 UaciiAamaabmaabaGafqiTdqMbaiaaaiaawIcacaGLPaaaaaa@48C3@ and k δ ⋅ f θ , g θ ˙  ,h θ ˙   and k θ MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGRbWaae WaaeaacqaH0oazaiaawIcacaGLPaaacqGHflY1daqadaqaaiGacAga daqadaqaaiabeI7aXbGaayjkaiaawMcaaiaacYcacaaMe8Uaci4zam aabmaabaGafqiUdeNbaiaaaiaawIcacaGLPaaacaaMe8UaaiilaiGa cIgadaqadaqaaiqbeI7aXzaacaaacaGLOaGaayzkaaGaaGjcVlaays W7caqGHbGaaeOBaiaabsgacaaMe8Uaam4AamaabmaabaGaeqiUdeha caGLOaGaayzkaaaacaGLOaGaayzkaaaaaa@5AF2@ are zero functions and A i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGbbWaaS baaSqaaiaadMgaaeqaaaaa@383E@ , B i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGbbWaaS baaSqaaiaadMgaaeqaaaaa@383E@ , E i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGbbWaaS baaSqaaiaadMgaaeqaaaaa@383E@ and H s c a l e i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGibGaam 4CaiaadogacaWGHbGaamiBaiaadwgadaWgaaWcbaGaamyAaaqabaaa aa@3CE6@ are not taken into account.
      • If stiffness function f ( δ ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGMbWaae WaaeaacqaH0oazaiaawIcacaGLPaaaaaa@3A78@ or f ( θ ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGMbWaae WaaeaacqaH4oqCaiaawIcacaGLPaaaaaa@3A89@ is requested, then K MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@ is used as a slope for unloading only.
      • If K MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@ is lower than the maximum slop of function f ( δ ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGMbWaae WaaeaacqaH0oazaiaawIcacaGLPaaaaaa@3A78@ or f ( θ ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaaciGGMbWaae WaaeaacqaH4oqCaiaawIcacaGLPaaaaaa@3A89@ ( K MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@ is not consistent with the maximum slope of the curve), K MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbbG8FasPYRqj0=yi0dXdbba9pGe9xq=JbbG8A8frFve9 Fve9Ff0dmeaabaqaciGacaGaaeqabaWaaeaaeaaakeaacaWGnbaaaa@3730@ is set to the maximum slope of the curve.
  8. Note that material density and inertia in /PROP/TYPE23 must not be null to ensure that the nodes connected by such a spring get a non-zero mass and inertia, unless they are secondary nodes of a rigid body, in which case unrealistically high stiffness and damping values are avoided.
    If the nodes connected by such a spring get a zero mass and inertia, they can still be secondary nodes of a rigid body, except for rigid bodies activated by a sensor. The rigid body cannot be set to OFF in the Radioss Engine.
    It is not possible to use elementary time step for springs with null density or null inertia in the model. Nodal Time Step or Advanced Mass Scaling must be used. If control time step is not set to Nodal Time Step, neither Advanced Mass Scaling in the Radioss Engine nor Nodal Time Step will be turned ON automatically.
