*MAT_024 (PIECEWISE_LINEAR_PLASTICITY)
LS-DYNA Input Interface KeywordDefines an isotropic elasto-plastic material using tabulated stress versus plastic strain input for different strain rates.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*MAT_024_{OPTION} or *MAT_PIECEWISE_LINEAR_PLASTICITY_{OPTION} | |||||||
mat_ID | ρi | E | υ | SIGY | ETAN | FAIL | |
C | P | LCSS | LCSR | VP | |||
EPS1 | EPS2 | EPS3 | EPS4 | EPS5 | EPS6 | EPS7 | EPS8 |
ES1 | ES2 | ES3 | ES4 | ES5 | ES6 | ES7 | ES8 |
Definition
OPTION |
mat_ID | Material
identifier. (Integer) |
ρi | Initial
density. (Real) |
[kgm3] |
E | Young’s
modulus. (Real) |
[Pa] |
υ | Poisson’s ratio. Default = 0 (Real) |
SIGY | Yield stress, ignored if
LCSS > 0 or stress-strain values
EPS1-EPS8,
ES1-ES8
specified. (Real) |
[Pa] |
ETAN | Plastic hardening modulus, not used
if LCSS > 0. (Real) |
[Pa] |
FAIL | Plastic strain to
failure. (Real) |
C | Strain rate
coefficient. (Real) |
[1s] |
P | Strain rate
exponent. (Real) |
LCSS | Stress versus plastic strain curve
or table identifier. (Integer) |
[Pa] |
LCSR | Curve identifier defining the
scaling coefficient for the stress-strain curve for a
corresponding strain rate. (Integer) |
VP | Strain rate type flag:
(Integer) |
EPS1-EPS8 | Plastic strain data
points. (Real) |
ES1-ES8 | Yield stress data
points. (Real) |
[Pa] |
- This keyword maps to /MAT/LAW36 (PLAS_TAB) when stress-strain curves are specified using LCSS or EPS and ES. If SIGY, ETAN, C, and P are used, then it maps to /MAT/LAW44 (COWPER).
- This material is only compatible with truss elements only when plasticity is specified through SIGY and ETAN.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
