/IMPVEL/LAGMUL
Block Format Keyword Defines imposed velocities on node groups using Lagrange multiplier method.
/IMPVEL/LAGMUL/impvel_ID/unit_ID | |||||||||
impvel_title | |||||||||
fct_IDT | Dir | Skew_ID | grnd_ID | ||||||
Ascalex | Fscaley |
Definition
impvel_ID | Imposed velocity block
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
impvel_title | Imposed velocity block
title. (Character, maximum 100 characters) |
fct_IDT | Time function
identifier. (Integer) |
Dir | Direction: X, Y, and Z in
translation; XX, YY, and ZZ in rotation. (Text) |
Skew_ID | Skew
grnd_ID | Identifier of the node
group on which the imposed velocity is applied. Input is obligatory.
The imposed velocities will be applied only on nodes that belong to
a node group. (Integer) |
Ascalex | Abscissa scale factor for
fct_IDT. Default = 1.0 (Real) |
Fscaley | Ordinate scale factor for
[ms] or [rads] |
- The velocity direction must be right justified in the ten characters of field number 2.
- The translational velocity is not available, if it is applied on a node with a null mass.
- The rotational velocity is not available, if it is applied on a node with a null inertia.
