/GRBEAM/BOX or /GRBEAM/BOX2
Block Format Keyword Describes the beam groups which are inside the box.
Only one box_ID is allowed:
/GRBEAM/BOX/grbeam_ID/unit_ID or /GRBEAM/BOX2/grbeam_ID/unit_ID
grbeam_title
box_ID
Definition
grbeam_ID Beam group identifier.
(Integer, maximum 10 digits)
unit_ID (Optional) Unit Identifier.
grbeam_title Beam group title.
box_ID Box identifier, which is defined in Boxes.
  1. If type is BOX, all elements having all nodes inside the box or on its surface are selected.
    If type is BOX2, all elements with at least one node inside the box or on its external surface are selected.
