RD-E: 4602 Euler Formulation
The purpose of this example is to show how to simulate the cylinder expansion test and compare the simulation result to experimental data.
Detonation is initiated at the bottom of the explosive. Radial expansion of the cylinder is measured and compared to experimental data.
The following features are used in the model:
  • Multi-material
  • Euler property formulation with Iale=2
  • Brick elements
Options and Keywords Used
Input Files
Before you begin, copy the file(s) used in this example to your working directory.
Modeling Video
Model Description
A OFHC copper cylinder (1.53cm diameter, 0.26cm thickness, 30.5cm height) is filled with an explosive (TNT). Detonation is initiated at the bottom of the explosive. Radial expansion is measured at a length of 8*D cm. With an Euler formulation, the air has to be modeled to measure radial expansion.
Since this problem is axisymmetric, only a quarter of the cylinder is modeled.
ex46_problem_description
Figure 2. Problem description for cylinder test
Units: cm, μ s, g, Mbar
Using the Multi-Material Solid, Liquid, and Gas material law (/MAT/LAW51), the copper cylinder material has the following characteristics using /MAT/HYD_JCOOK:
Material Properties
Value
Rho_Initial
8.96 (g/cm3)
Young's modulus
0.4229 (Pa)
Poisson coefficient
0.33
Yield stress
0.0009 (µBar)
Hardening parameter
0.00292 (µBar)
Hardening exponent
0.31
Strain rate coefficient
0.025
Reference strain rate
1e-06
Specific heat per volume
1e+20
EoS_Options_Input (Polynomial)
  • C0 1e-06 (µBar)
  • C1 = 1.38 (µBar)
  • C2 = 1.372 (µBar)
Radioss Card (Copper)
##HWCOLOR materials 10 4
/MAT/LAW51/10
LAW_51_Copper
#    Iform
        12
#                                     NU              Nu_Vol
#    MatID           ALPHA_MAT
         1                 1.0
#    MatID           ALPHA_MAT
         1                 0.0
#    MatID           ALPHA_MAT
         3                 0.0
#    MatID           ALPHA_MAT
         2                 0.0
Using Multi-Material Solid, Liquid, and Gas material law (/MAT/LAW51), the TNT material has the following characteristics using /MAT/LAW5 (JWL):
Material Properties
Value
Rho_initial
1.63 (g/cm3)
A parameter EoS
3.712 (µBar)
B parameter EoS
0.0323 (µBar)
R1 parameter EoS
4.15
R2 parameter EoS
0.95
Omega parameter EoS
0.3
Detonation velocity
0.693
Chapman Jouguet pressure
0.21 (µBar)
Detonation Energy per Unit Volume
0.07
Initial pressure
1e-06
Unreacted explosive bulk modulus
0.036
Radioss Card (TNT)
##HWCOLOR materials 11 4
/MAT/LAW51/11
LAW_51_TNT
#    Iform
        12
#                                     NU              Nu_Vol
#    MatID           ALPHA_MAT
         1                 0.0
#    MatID           ALPHA_MAT
         1                 0.0
#    MatID           ALPHA_MAT
         3                 0.0
#    MatID           ALPHA_MAT
         2                 1.0
Using the Multi-Material Solid, Liquid, and Gas material law (/MAT/LAW51), the Air material has the following characteristics using /MAT/HYD_VISC:
Material Properties
Value
Rho_Initial
0.0012 (g/cm3)
EoS_options_Input (IDEAL_GAS)
  • Heat Capacity Ratio = 1.4
  • Initial Pressure = 1e-06 (µBar)
Radioss Card (Air)
##HWCOLOR materials 12 4
/MAT/LAW51/12
LAW_51_Air
#    Iform
        12
#                                     NU              Nu_Vol
#    MatID           ALPHA_MAT
         1                 0.0
#    MatID           ALPHA_MAT
         1                 0.0
#    MatID           ALPHA_MAT
         3                 1.0
#    MatID           ALPHA_MAT
         2                 0.0
Using the Multi-Material Solid, Liquid, and Gas material law (/MAT/LAW51), the Boundary material has the following characteristics.
Radioss Card (NRF)
##HWCOLOR materials 4 6
/MAT/LAW51/4
NRF
#    Iform
         6
#               Pext                           Tcp            Tc_alpha
#            ALPHA_1              RHO_01                E_01              P_min1                P_01
                 0.0                 0.0                 0.0                 0.0                 0.0
#             SSP_01
                 0.0
#    BLANK CARD
                 0.0                 0.0                 0.0                 0.0                 0.0
#             SSP_01
                 0.0
#    BLANK CARD
                 0.0                 0.0                 0.0                 0.0                 0.0
#             SSP_01
                 0.0
#    BLANK CARD
Model Method
A 3D mesh is made of brick elements. The element size for the copper cylinder is approximately 0.035 cm x 0.035 cm x 0.035 cm.
The mesh is dragged along the z direction (z = 30.5 cm). It is important to have no discontinuity in element volume to ensure a good propagation of detonation wave and shock wave.
The model is constraint in translational x-, y-, z- direction.
Figure 3. Boundary condition
A planar detonation wave is defined at the bottom of the cylinder. A scale factor of 0.5 (on time step for all elements) is used for this type of application.
Property /PROP/SOLID with EULER property formulation Iale = 2 is used.
#                q_a                 q_b                   h            LAMBDA_V                MU_V
#             dt_min   istrain      IHKT
##HWCOLOR properties 1 3
/PROP/SOLID/1
ALE_PROP
#   Isolid    Ismstr      Iale     Icpre  Itetra10     Inpts   Itetra4    Iframe                  Dn
         0         0         2                                        0
#                 qa                  qb                   h              Lambda                  Mu
                 1.1                0.05                                     0.0                 0.0
#         deltaT_min
                 0.0
Results
Figure 4 displays the variation of density and pressure in the cylinder, explosive and air. Energy balance is also displayed.
ex46_density-2
Figure 4. Density and pressure distributed in copper and TNT at time = 40µs. Energy balance is also displayed.
Figure 5 shows the comparison between the experimental and simulation measurement of radial expansion. The displacement values are estimated on the animations using the density contour.
ex46-2_comparison
Figure 5. Comparison between experimental results and simulation results
Conclusion
Good correlation between experimental and simulation results. A thinner meshing could improve the correlation between simulation and experimental curves.
1
Adiabatic Expansion of high explosive detonation products, LANL, Wilkins (1969)
2
A Constitutive model and data for metals subjected to large strains, high strain rates and high temperatures, Gordon R. Johnson, William H. Cook
