/DT/AIRBAG/Keyword3
Engine Keyword Time step with airbag and time step control.
/DT/AIRBAG/Keyword3
ΔTsca ΔTmin
Definition
Keyword3 | Time step control type:
If Keyword3 is not specified, that is, /DT/AIRBAG, then the entered ΔTmin is not used. |
ΔTsca | Scale factor on critical
time step for airbag. Default = 0.9 |
ΔTmin | Minimum time step. |
- /DT/AIRBAG/Keyword3 can be combined with /DT/NODA or /DT/NODA/CST.
