*CONTACT_ERODING_SINGLE_SURFACE
LS-DYNA Input Interface KeywordDefine automatic single contact interface set of shell and solid elements.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*CONTACT_ERODING_SINGLE_SURFACE_{OPTION3} |
If OPTION3 = ID:
inter_ID | Title | ||||||
SSID | SSTYP | ||||||
FS | FD | DC | Tstart | Tstop | |||
SFS | SST | SFST | FSF |
Optional Card A
SOFT |
Definition
OPTION3 |
inter_ID | Contact interface
identifier. (Integer) |
Title | Contact interface
title. (Character, maximum 70 characters) |
SSID | Set or part
SSTYP | Input set type.
(Integer) |
FS | Static friction
coefficient. (Real) |
FD | Dynamic friction
DC | Exponential decay
[sm] |
Tstart | Start time. (Real) |
[s] |
Tstop | Stop time. Default = 1E+30 (Real) |
[s] |
SST | Stiffness scale
factor. (Real) |
SFS | Maximum gap
value. (Real) |
[m] |
SFST | Contact gap
scale. (Real) |
FSF | Coulomb friction coefficient scale
factor. (Real) |
SOFT | Contact stiffness definition flag.
(Integer) |
- This keyword maps to /INTER/TYPE25.
