/ALE/GRID/DONEA
Block Format Keyword Velocity of a given grid node depends on velocity and displacements of neighboring grid nodes.
/ALE/GRID/DONEA
α γ Fscalex Fscaley Fscalez
Vmin
Definition
α DONEA coefficient.
Default = 0.0 (Real)
γ Grid velocity limitation factor.
Default = 100 (Real)
Fscalex X grid velocity scale factor.
Default = 1.0 (Real)
Fscaley Y grid velocity scale factor.
Fscalez Z grid velocity scale factor.
Vmin Elements with a volume less than Vmin will be deleted.
Default = -1030 (Real)
[m3]
  1. This option is available for 2D and 3D analysis.
  2. Further explanation about this formulation can be found in ALE Formulation in the Radioss Theory Manual.
