Integrated Diagnostics - Contributions Tab
Perform contribution analysis for the vehicle response between sensitivity and forces, with the respective files loaded in the Loadcase Processing tab, the vehicle response calculated or loaded, and the loadcases selected in the Vehicle Response tab, Powertrain input, or Road Profile input.
Order Contribution Tab
Overall response is plotted after you have selected the powertrain input loadcase in the Vehicle Response tab with the corresponding sensitivity and forces result file in the Loadcase Processing tab. The Order Contribution tab allows you to plot the waterfall diagram and perform order cut analysis.
- Order Cuts
- After viewing the surface plot, use the Start, End, and Step fields to specify the orders you want to see by cutting the surface plot.
- 3D Surface
- Creates a 3-D Surface plot of the response within an RPM range.
Load Path Contribution
After you have selected the powertrain inputs loadcase in the Vehicle Response tab, with the corresponding sensitivity and forces results file in the Loadcase Processing Tab, the Load Path Contribution tab allows you to perform contribution analysis with respect to the sensitivity and forces for an RPM sub-case based on the vehicle response.
- Bar
- Creates a bar plot of the response at a specific frequency.
- 2D Line
- Creates a 2-D line plot of the response for a range of frequency.
- Frequency range
- Select the frequency range that the response curves should be plotted within.
Wheel Contribution Tab
After you have selected the road profile inputs loadcase in the Vehicle Response tab with the corresponding sensitivity and forces results file in the Sensitivity and Forces Tab, the Wheel Contribution sub-tab allows you to perform a contribution analysis with respect to the wheel contribution and sensitivity for a vehicle response, corresponding to the random loads subcase.
- Bar
- 2D Line
- Frequency range
