Highlight the connector(s) you want to split, then right-click and select Split > Style option from the context menu.
Highlighted connectors of a different style are not considered for the split
operation.
Unless requested from the split settings, the split operation of a realized line
connector will not unrealize the individual single point connectors. Newly created
split connectors will be created in the component of the original connector.
Split Settings
Settings used to define how connectors are split.
Access Split Settings by right-clicking on a connector and selecting Split > Split Settings from the context menu.
Table 1.
Option
Unrealize
During the Split operation of a realized line connector, the
individual single point connectors will be unealized.
