After including a text parameter, click the ellipse, , to display the
More Options dialog.
If the ellipse button is grayed out, that indicates that advanced settings are not
available for a particular attribute.
From this dialog, you can change the following report parameter attributes:
Name
The name of the parameter, as listed in the Name column in the parameter
table.
Value type
The following options are available:
value: Replaces the entire string value with an
entered value when the script is run.
prefix: Adds a prefix to a curve name.
suffix: Adds a suffix to a curve name.
search and replace: Searches and replaces
values in the curve name.
range: Replaces all characters within the
selected range.
Default value
The default value which can be overwritten when the script is run.
Remove Parameter
Deletes the parameter.
Add Parameter
Adds another parameter to the same attribute. It has a different default
name, but the same default values as the original parameter in the
dialog. Click OK to
close the Advanced Settings dialog and add the new
parameter to the Parameters Browser.
Undo
Removes the defined parameters for a block of text. This is only
available for range and search and replace.
