Create and Edit Joint Legs
Use the Joint Legs tool to add, delete, and move joint leg ends around the face of a bounding box.
From the Skeleton ribbon, click the Joint Legs
tool.
Figure 1. - Select a joint hub to edit.
Do one of the following:
- Click
to add a new joint leg.
- Select a joint leg then click
to delete it.
- Select a joint leg and click
to reposition it along the bounding box's face.
- Click
to align two opposite joints
Figure 2. - Click
On the guide bar, click one of the following:
- Apply and stay in the tool
- Apply and close the tool
- Exit the tool without applying
Align Joints
Use the Align tool to align joints to an anchor.
From the Skeleton ribbon, Joint Legs tool group, click the
Align tool.
Figure 3. - Select the anchor joint – the joint that will not move.
Select the joints you want to move.
The joint composition is not altered during alignment.
- Select a global direction.
