Break
Add a page break to the report.
- Right-click at the Report or Chapter level and select
Or
From the Report ribbon, click the arrow next to the Add Item, then select Break.
. - Below are the properties associated with the Break entity.
Figure 1. - Name
- You change the name property of the break item.
- Orientation
- Select the page break type. The page breaks also change the
orientation of the following pages in the exported report.
Restriction: Section breaks are not supported on Linux.
