Reorder Entities
Change the order of named entities in database.
Changing this order affects the display and entity selection, and the order in which these entities are plotted.
Press Ctrl+F or click the search
bar in the modeling window and type
Reorder.
Figure 1. Note: This tool can only be accessed by search. - Select an entity type and then the specific entities you wish to reorder.
Select whether entities are sorted by name or ID.
If you choose neither, the selected entities are moved in the list, but maintain their order relative to each other.
- Choose where the entities are positioned in the list (front or back).
- Click Reorder.
