Release Degrees of Freedom
Use the Edit Beam: Pins tool to edit and release degrees of freedom.
You can select a single element at a time and review or edit the released degrees of freedom at node A and node B.
From the 1D ribbon, click the tool.
Figure 1. - Select a beam element.
- Move the node A and node B microdialogs so that they are both visible.
- Click the appropriate translate or rotate button depending on which axis you would like to affect.
