Edit Edge Density and Element Size
Use the Map: Density tool to edit element density and size along source/target surface edges.
From the 3D ribbon, click the tool.
- Optional: On the guide bar, click to define surface mesh options.
- Left-click to select the edge(s) to modify.
- In the microdialog, click the icon to switch the value being defined to either element density or element size.
Edit element density or size in the following ways:
- Increase individual edge values by holding Ctrl while left-clicking on an edge; decrease individual edge values by holding Ctrl while right-clicking on an edge.
- Scroll edge values by holding Ctrl while scrolling the mouse wheel up and down. Hovering directly over an edge will only modify that edge; hovering over empty space will modify all selected edges.
- Specify an edge value in the microdialog and press Enter. If multiple edges are selected, a common value will be applied. If multiple edges with different edge values are selected, use the arrows in the microdialog to modify individual edge values simultaneously, without applying a common value.
Mesh to update the map mesh.
If the Auto update option is tuned off, first click Update to modify the 2D mesh.
Tip: Clear your selection by left-clicking in empty space.
