Fatigue Configuration File
The Fatigue Configuration file is a user-defined, external ASCII file, which can be used to read the data groups of static, modal, and transient analysis results from different solvers.
- The local working directory.
- Your home directory (looks at the "HOME" environment variable).
- The HyperView bin directory.
Each fatigue configuration file consists of one or more data groups. Each data group is defined by a group name, denoted by an asterisk, ‘*’, at the beginning of the group name line, followed by 1-12 data type lines.
You can comment out any line in the HVFatigue.cfg file by placing a pound symbol, ‘#’, a dollar sign, ’$’, or a forward slash, ‘/’, at the beginning of the line.
*My Unique Group
SX = Normal Stress X (solids)
SZ = Normal Stress Z (solids)
#SXY = Shear Stress XY (solids)
SYZ = Shear Stress YZ (solids)
SXZ = Shear Stress XZ (solids)
Valid Data Types
Stresses = SX, SY, SZ, SXY, SYZ, SXZ
Strains = EX, EY, EZ, EXY, EYZ, EXZ
Stresses = SX1, SY1, SZ1, SXY1, SYZ1, SXZ1, SX2, SY2, SZ2, SXY2, SYZ2, SXZ2
Strains = EX1, EY1, EZ1, EXY1, EYZ1, EXZ1, EX2, EY2, EZ2, EXY2, EYZ2, EXZ2
Depending on which type of group you are defining, the fatigue manager assumes that any undefined data type identifiers, which are allowed, be set to 0. If you provide an improper data type identifier, such as one that is not on any of the above lists, the line is ignored.
Negation
SX = Normal Stress X (solids)(SX = 0.2)
SX = -Normal Stress X (solids)
SX = Normal Stress X (solids); -1.0(SX = -0.2 in either case)
