Split with Surfaces
Use the Split: Surfaces tool to split surfaces and solids using surfaces.
Note: Splitting FE geometry surfaces with other FE
geometry surfaces is supported; however, the extend trimmer option is not.
From the Topology ribbon, click the tool.
Figure 1. - Select Surfaces or Solids from the Target selector on the guide bar.
- Select target surfaces/solids.
- Optional:
On the guide bar, click
to define split options.
- Activate the Tool selector on the guide bar.
- Select the surface(s) used to split.
- Optional:
Review the split sections.
Restriction: Only available when splitting solids.
- Click Split on the guide bar.
