Apply Thickness to Midsurface
Use the Map Thickness tool to apply thickness values to shell elements on midsurfaced geometry.
The thickness will be assigned on the midmesh either on node card, element card, nodal thickness on element card or also as properties on elements depending on the solver interface you are using.
Restriction: Only available in the OptiStruct,
Radioss, Abaqus,
LS-DYNA, PAM-CRASH 2G, or
Nastran solver interfaces.
From the 2D ribbon, click the Map Thickness tool.
Figure 1. - Optional:
On the guide bar, click
to define map thickness options.
- Activate the Source selector on the guide bar, choose an entity type, then select source entities.
- Activate the Target selector on the guide bar, choose an entity type, then select target entities.
- On the guide bar, click Apply Thickness.
Options for Map Thickness
Access the following options by clicking on the
Elements ribbon: Map Thickness tool
guide bar.
Define Thickness Options
- Minimum thickness/Maximum thickness
- Define a thickness to assign calculated thicknesses.
- Assign offset to elements/sections
- To assign an offset value to elements if they are not in the middle of
the selected geometry, select the Assign offset to
elements/sections checkbox.
Figure 3. Element Offset Off Figure 4. Element Offset On - Group elements by thickness interval
- Automatic Method
- Groups elements with similar thicknesses together, and assigns an average thickness to the groups based on the “Factor of thickness” interval range input.
- Method Fixed Interval
- Control thickness properties at constant intervals.
- Merge isolated elements with adjacent groups
- Merges isolated elements into adjacent groups. The tolerance factor is used to determine if the element is going to be regrouped by “Thickness Variation Factor”. Range (0, 1.0). For example, if the value is 0.2, elements can only be regrouped if the percentage change in thickness is going to be less than 20%.
- Thickness precision
- Round the thickness values up or down to have the same number of decimal digits as the input value in the Maximum thickness range interval field. There are three modes available. Automatic determines an optimal truncation.
- Scaling at corners [0,10]
- Enter a scaling factor to use when interpolating thickness values near
t-junctions or corners. A value less than 1 will result in linear
decrease in the thickness values nearer to the junction/corners. A value
of zero will result in an approximate mass-conserved thickness
estimation. When equal to 1, the thickness is extrapolated /
interpolated without any scaling. When greater than 1, the thickness
will increase as you go closer to the junction.
Figure 8. Scaling = 0, Thickness Contour Applied, Traditional Element Visualization Figure 9. Scaling = 0, Thickness Contour Applied, 2D Detailed Element Representation Figure 10. Scaling = 1, Thickness Contour Applied, Traditional Element Visualization Figure 11. Scaling = 1, Thickness Contour Applied, 2D Detailed Element Representation
