Create Gap Elements
Use the Gaps tool to create 0D/1D gap elements.
A gap element is an element created in a space between two nodes.
  1. From the 1D ribbon, select the Gaps 0D or Gaps 1D tool.
  2. Define the element.
    OptionAction
    Type Select an element type.
    Linear 1D Create one-dimensional elements based on a projection of Elems A to Elems B.
    Elems A Select the elements where you want the elements to begin.
    Restriction: Only available when the Linear 1D check box is selected.
    Elems B Select the elements where you want the elements to end.
    Node A Select the element's starting node.
    Note: Node A is required for 0D elements.
    Node B Select the element's ending node.
    Density A-B Specify the number of gap elements you want created between each of the selected elements.
    Orientation Type Choose between methods of orienting the element. Orientation is only necessary when the nodes are coincident.
    Default
    Do not use an orientation. If necessary, use the global coordinate system.
    Direction
    Select three points to define a plane whose normal serves as the vector using the N1, N2, and N3 selectors.
    Node
    Specify a node, the vector from the coincident nodes to this one is the orientation vector.
    System
    Orient the element based on a selected local system coordinate.
    Property Select a property to assign to new and existing gap elements.
  3. Click Create.
Update Gap Elements
Use the Entity Editor to update gap elements for the desired keyword.
This includes modifying the assigned nodes, property, orientation, and so on where applicable for the solver.
Note: To change the element type, see Change Element Type.
