AVEVA Marine Reader
Supported Entities
- Plane panels
- Curved panels
- Knuckled panels
- Plane plates
- Curved plates
- Pillars
- Stiffeners (also with sub-flanges)
- Curved stiffeners
- Face plates (also with sub-flanges)
- Flanges
- Brackets
- Doubling profiles
- Hole profiles
- Marking profiles
- Seam profiles
- Swage profiles
- Tap profiles
@CreationType
= TreeOfComponents
, an assembly
tree is created and organized as follows:- 1 assembly corresponding to the whole ship (1 ship per part).
- 1 assembly per block.
- 1 assembly per PlanePanel.
- 1 component for the detailed contour of the current PlanePanel (with relevant option).
- 1 component for the simple contour of the current PlanePanel (with relevant option).
- 1 component per PlanePlateGroup. The material name, material
side, thickness and offset are created as metadata. If
material data are available, a PSHELL material is
created.
- 1 surface per PlanePlate. The profile existing in the file is used for the external loop. Holes can be added as internal loops (with relevant option).
- 1 component per PlanePillarGroup.
- 1 set of trace lines per PlanePillar.
- 1 surface per web (with relevant option).
- 1 component per PlaneFlangeGroup.
- 1 set of trace lines per PlaneFlange.
- 1 component per PlaneStiffenerGroup.
- 1 set of trace lines per PlaneStiffener.
- 1 surface per web and per flange (with relevant option).
- 1 component per PlaneFaceplateGroup.
- 1 set of trace lines per PlaneFaceplate.
- 1 assembly per sub-PlanePanel. The contents correspond to the ones for normal PlanePanels.
- 1 assembly per PlaneBracketGroup.
- 1 component per bracket if no sub-elements exist
(stiffeners, planeplates, flanges). 1 assembly if
sub-elements exist.
- 1 surface per PlaneBracket. The profile existing in the file is used for the external loop. No holes are allowed by the AVEVA Marine format. If sub-elements are present in the current PlaneBracketGroup, a specific component is created for the surface in order to keep it separate from its sub-elements.
- 1 component per PlaneStiffenerGroup sub-element (no flanges inside the stiffener group are allowed).
- 1 component per PlaneFaceplateGroup sub-element (no flanges inside the faceplate group are allowed).
- 1 component per PlaneFlangeGroup sub-element.
sub-elements exist.
- 1 assembly per CurvedPanel.
- 1 component for the simple contour of the current CurvedPanel (with relevant option).
- 1 component per CurvedPlateGroup.
- 1 surface per CurvedPlate. The profile existing in the file is used for the external loop. Internal holes are implemented.
- 1 component per CurvedStiffenerGroup.
- 1 set of trace lines per CurvedStiffener.
- 1 assembly per KnuckledPanel.
When @CreationType
is “Parts
”, a corresponding tree
is created but no assembly entities are created, parts are created instead. The
components are also created.
When @CreationType
is “BOM Only
”, a corresponding
tree is created with parts as in the previous case, but no components are actually
created.
PlanePlates, CurvedPlates and PlaneBrackets are mapped as surfaces. Other objects are imported as curves, lying on the plates. Groups of objects may share similar properties (such as material, material side, thickness and offset). In this case, metadata are added to these objects, and if possible the material description is also created. Holes of curved surfaces are not taken into consideration for this release.
The reader instantiates objects in their nominal position, hence there may be gaps between panels, brackets, and so forth, due to idealizations that do not take thickness into account. Hence, no stitching between surfaces is performed on import.
Available material fields include Young's modulus, Poisson's ratio, expansion coefficient, and density. Yield stress and ultimate stress are not imported. Each material is associated with a unique grade name.
When a thickness is provided, the corresponding value is given to a property.
Objects affected by material/thickness include PlanePlateGroup, PlanePillarGroup, PlaneFlangeGroup, PlaneStiffenerGroup, PlaneFaceplateGroup, PlaneBracketGroup, CurvedPlateGroup and CurvedStiffenerGroup.
Import Options
Value | Description |
on |
Assign body identifier as
metadata.
off |
Do not assign body identifier as metadata (default). |
double |
A negative value (default) indicates to use the auto cleanup tolerance. A value greater than the calculated auto cleanup tolerance indicates to use that specific tolerance. Refer to the CAD Import Options. |
integer |
Read color attributes of geometric entities as metadata with integer values.
on |
Read color attributes of geometric entities as metadata.
off |
Do not read color attributes (default). |
Parts |
Generate a full part-based hierarchy. |
BOMOnly |
Generate an empty part-based hierarchy. |
TreeOfComponents |
Generate an assemblies/components based hierarchy. |
PackIntoSinglePart |
Consolidate hierarchy into a single part. |
string |
A RGB description of the color to use for curved plates, with values ranging
from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color
management will be utilized. The obsolete @TribonCurvedPlateColor
is corresponding to this option and still supported. |
string |
A RGB description of the color to use for curved simple contours, with values
ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color
@TribonCurvedSimpleContourColor is corresponding to this option
string |
A RGB description of the color to use for curved stiffeners, with values
ranging from 0.0 to 1.0 (e.g. "0.1,0.5,0.4"). If not specified, default color
@TribonCurvedStiffenerColor is corresponding to this option and
still supported. |
on |
Preserve the original geometry edges, instead of merging them together during the import cleanup phase. |
off |
Merge edges together during the import cleanup phase (default). |
on |
The imported surfaces are extended to match neighbor surfaces (default). |
off |
The imported surfaces are not extended. |
string |
A RGB description of the color to use for flanges, with values ranging from 0.0
to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will
be utilized. The obsolete @TribonFlangeColor is corresponding to
on |
Import cutout profiles. |
off |
Do not import cutout profiles (default). |
on |
Import doubling profiles. |
off |
Do not import doubling profiles (default). |
on |
Import faceplates as surfaces if the surface description is present in the file, otherwise import as curves (default). |
off |
Import faceplates as curves. |
on |
Import hole profiles. |
off |
Do not import hole profiles (default). |
on |
Create holes (default). |
off |
Do not create create holes. |
on |
Import marking profiles. |
off |
Do not import marking profiles (default). |
on |
Import notch profiles. |
off |
Do not import notch profiles (default). |
on |
Create curves along the panel profiles. |
off |
Do not create curves along the panel profiles (default). |
on |
Import pillars as surfaces if the surface description is present in the file, otherwise import as curves (default). |
off |
Import pillars as curves. |
on |
Import seam profiles. |
off |
Do not import seam profiles (default). |
on |
Import stiffeners as surfaces if the surface description is present in the file, otherwise import as curves (default). |
off |
Import stiffeners as curves. |
on |
Import swage profiles. |
off |
Do not import swage profiles (default). |
on |
Import tap profiles. |
off |
Do not import tap profiles (default). |
on |
Import curved plates lacking boundary descriptions (default). |
off |
Do not import curved plates lacking boundary descriptions. |
on |
Stiffener lines are projected onto close surfaces and create corresponding topological modifications to these surfaces (default). |
off |
No projection is performed. |
on |
Generate metadata with the original CAD hierarchy within the
part.
off |
Do not generate metadata with the original CAD hierarchy within the part (default). |
string |
The string is prefixed to all metadata names. No prefix is used by
default. See CAD Metadata Naming for more details. |
string |
A RGB description of the color to use for plane brackets, with values ranging
management will be utilized. The obsolete @TribonPlaneBracketColor
string |
A RGB description of the color to use for plane cutouts, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized. |
string |
A RGB description of the color to use for plane detailed contours, with values
@TribonPlaneDetailedContoursColor is corresponding to this option
string |
A RGB description of the color to use for plane doublings, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized. |
string |
A RGB description of the color to use for plane faceplates, with values ranging
@TribonPlaneFaceplateColor is corresponding to this option and
still supported. |
string |
A RGB description of the color to use for plane flanges, with values ranging
management will be utilized. The obsolete @TribonPlaneFlangeColor
string |
A RGB description of the color to use for plane hole profiles, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized. |
string |
A RGB description of the color to use for plane marking profiles, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized. |
string |
A RGB description of the color to use for plane notch profiles, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized. |
string |
A RGB description of the color to use for plane pillars, with values ranging
management will be utilized. The obsolete @TribonPlanePillarColor
string |
A RGB description of the color to use for plane plates, with values ranging
management will be utilized. The obsolete @TribonPlanePlateColor is
string |
A RGB description of the color to use for plane seam profiles, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized. |
string |
A RGB description of the color to use for plane simple contours, with values
@TribonPlaneSimpleContourColor is corresponding to this option
string |
A RGB description of the color to use for plane stiffeners, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized. The obsolete @TribonPlaneStiffenerColor is corresponding to this option and still supported. |
string |
A RGB description of the color to use for plane swage profiles, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized. |
string |
A RGB description of the color to use for plane tap profiles, with values ranging from 0.0 to 1.0 (for example "0.1,0.5,0.4"). If not specified, default color management will be utilized. |
on |
When multiple representations of a AVEVA Marine object are available, import the most complex one (default). |
off |
When multiple representations of a AVEVA Marine object are available, import the least complex one. |
double |
Define the model scaling factor during import. Default is 1.0. |
Part |
Generate part-based component (only allowed value if
CreationType =Parts ). |
General |
Keep component as in CAD (only allowed value if
CreationType =TreeOfComponents ). |
on |
Edges of close surfaces are stitched together (default). |
off |
Edges of close surfaces are not stitched together. |
string |
A RGB description of the color to use for sub-faceplates, with values ranging
management will be utilized. The obsolete @TribonSubFaceplateColor
string |
A RGB description of the color to use for sub-stiffeners, with values ranging
management will be utilized. The obsolete @TribonSubStiffenerColor
CAD units |
Keep the units of the CAD files (default for GUI). |
MKS [m kg N s] |
Convert to the corresponding units system. |
MMKS [mm kg N s] |
MPA [mm t N s] |
CGS [cm g dyn s] |
MMKNMS [mm kg kN ms] |
MMGNMS [mm g N ms] |
IPS Std [in pounds lbf s] |
IPS Grav [in slinch lbf s] |
FPS Std [ft pounds lbf s] |
FPS Grav [ft slug lbf s] |
Scale factor |
Apply the corresponding scale factor (default for no GUI to allow supporting legacy scripts). |
Supported Metadata
Type | Entities | Description |
string |
comps, assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value is a string indicating the role of the object. Currently created
values include:
entity |
parts | Stiffener groups might contain this metadata which points the corresponding BEAMSECTION entity. |
string |
comps, assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the BendingRadius attribute for a plane faceplate group, a plane
flange group, a plane pillar group, or a plane stiffener group. Possible values are:
string |
comps, assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the BendingRadius attribute for a plane flange group. |
string |
Identifier of the CAD body containing the entity. Generated when
string |
Three RGB values, ranging from 0 to 255, indicating the color for the object. Generated when the corresponding |
string |
surfs | The value of the CompId attribute for a plate or bracket. |
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the DataType attribute for a panel. |
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the maximum extent of a block or panel, as retrieved from the Max attribute of the object. |
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the minimum extent of a block or panel, as retrieved from the Min attribute of the object. |
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the ForceUnits attribute for a ship units object. |
string |
assems | The value of the FunctionalProperty attribute for a panel or a group of sub-objects of a panel. |
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the Height attribute for a plane flange group. |
double array |
assems | An array of 6 double values is added to each line belonging to pillars, flanges, stiffeners, and faceplates. Each line is provided with two triplets of inclination values to form 2 unit vectors. The vectors indicate the inclinations at the endpoints of the lines in the absolute reference system. |
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | Two possible values: AsDefined or Reflected, to indicate if the object is on the same side as its definition data, or if it has been reflected. |
string |
Hierarchy of an entity within a part. Generated when
string |
assems if hierarchy as Assemblies; parts if heirarchy as Parts | The value of the LengthUnits attribute for a ship units object. |
entity |
parts | Plate groups and stiffener groups might contain this metadata which points to the corresponding MATERIAL entity. |
string |
faces | The value of the MaterialDirection attribute for a flange, curved panel or knuckled panel. |
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the material side data for a plate group or bracket group. |
integer |
comps if hierarchy as Assemblies; parts if hierarchy as Parts | Model units specified in the CAD file.
This is always generated. |
string |
parts | A string given to parts to indicate their role in the ship organization.
Supported types include:
string |
assems if heirarchy as Assemblies; parts if hierarchy as Parts | The value of the offset data for a plate group. |
double |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the thickness attribute for any object having a material whose description includes a thickness. |
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the Type attribute for a ship rendering object. |
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | Generated for root system assemblies. Its value is the XML field OID. |
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the Thickness attribute for a plane flange group. |
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the Tightness attribute for a panel. Allowed values include:
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the Version attribute for a ship. |
string |
assems if hierarchy as Assemblies; parts if hierarchy as Parts | The value of the WeightUnits attribute for a ship units object. |
