Parameter entities parameterize FE entity and geometric entity attributes.
Abaqus Cards
To properly read and import parameters, independent parameters must be defined before
dependent parameters. If parameters are not properly defined, Abaqus will abort the evaluation, and an error message will
display.
In the image below, parameter2 must be defined ahead of parameter1.
Figure 1. Parameters are evaluated and their values are determined by the solver. The final
value, after the evaluation of the parameter, will be written in the input deck. The order
in which the parameters are written determines the value assigned to the parameter. The
value of Parameter1, regardless of where Parameter1 is written in the input deck, will be
2.
During export, parameters are exported in the order in which they were created. Parameter
information is written at the top of the input deck. If a parameter is in an Include file,
then it will be written at the top of the Include file.
The keywords, *Parameter Dependence and *Parameter Table are not yet supported.
Card
*PARAMETER
Defines numerical values through algebraic expressions of parameter names
referenced throughout the input file.
Note: Supported:
Parameters can be created, imported, and exported.
Edit parameters in the Entity Editor.
Parameter expressions are evaluated on the fly.
Parameter expressions can reference another parameter.
If you edit the value of a parameter, the other parameters that references
it will be updated accordingly.
Edit parameterized variables in the Entity Editor.
You can create and assign parameters from the fields of an entity in
Entity Editor.
Load magnitude, element node ID, Node coordinate, and so on can all be
parameterized.
Limitations:
Support is limited to all properties and materials.
Parameterization of entity IDs is not supported.
Unsupported parameterized entities and fields are replaced with
corresponding parameter values during import, to avoid the loss of
data.
In macros and browsers, if any parameterized variable is changed, you will
receive a warning message in the message bar and the value will not be
updated.
The creation of duplicate parameters is not supported. During import,
duplicate parameters and their corresponding expression will be replaced
with the resolved value in the input deck.
LS-DYNA Cards
Card
*PARAMETER
*PARAMETER_LOCAL
Defines numerical values of parameter names referenced throughout the input
file.
Note: Supported:
Edit parameter expressions in the Entity Editor.
A parameter expression can reference another parameter.
Edit parameterized values in the Entity Editor.
Same parameters can be used for negation by prefixing negative signs
Entity Editor.
Parameters can be referenced in angular brackets, along with the usual
reference using “&”.
When more than one *PARAMETER with the same name exist in a deck, the
first one will be retained.
Parameters with same names are maintained when *PARAMTER_LOCAL is used and
they are specified in different include files.
Free format is supported.
Limitations:
Support is limited to all FE entities except elements and nodes.
Parameterization of entity ID’s is only supported for Components,
Properties, Materials and Curve.
Parameterization of entity ID’s is not supported.
data.
In macros and browsers, if any parameterized variable is changed a warning
message will appear in the message bar and the value will not be
updated.
*PARAMETER_EXPRESSION
*PARAMETER_EXPRESSION_LOCAL
Note: Supported:
You can edit parameters and parameter expressions in the Entity Editor.
Parameter expression can reference another parameter.
When more than one *PARAMETER_EXPRESSION with the same name exists in a
deck, the first one will be retained.
Parameters with the same names are maintained when
*PARAMTER_EXPRESSION_LOCAL is used and they are specified in different
include files.
Limitations:
Properties, Materials and Curves.
data.
In Macros and Browser, if any parameterized variable is changed a warning
updated.
Nastran Cards
Card
%DEFREPSYM
Defines default parameter values.
Note: Can be created, imported, and
exported.
Edit in the Entity Editor.
%DEFREPWIDTH
Defines default width information.
Note: Automatically created during export
when a parameter is created in HyperMesh.
%SETREPSYM
Defines default values.
Note: Cannot be created in HyperMesh, only imported and exported.
%UNDEFREPSYM
Clears or unsets default parameter values.
%UNSETREPSYM
Clears or unsets parameter values.
Materials that can be parameterized in the NastranMSC user
profile.
MAT1
MAT10
MAT2
MAT4
MAT5
MAT8
MAT9
MATEP
MATG
MATHE
MATHP
Properties that can be parameterized in the NastranMSC user
profile.
PAABSF
PACBAR
PACINF
PAERO2
PBEND
PBUSH
PBUSH1D
PCOMP
PCOMPG
PCOMPP
PCONVM
PWELD
PDAMP
PELAS
PELAST
PFAST
PGAP
PHBDY
PMASS
PROD
PSEAM
PSHEAR
PSHELL
PSHELL1
PTUBE
PVISC
OptiStruct Cards
The parameter entity is supported in the OptiStruct
interface, however support is limited to parameters that are created in HyperMesh and associated with parameters in HyperStudy.
Scope is limited to material and property entity types. Also, within those entity
types, parameterization is restricted to template attributes of type double.
Parameterized attributes are unparameterized with their original value during
export.
Parameters cannot be exported or imported.
Radioss Cards
Card
/GLOBAL/INT_EXPR/
Note: Supported:
Edit parameter expressions in the =Entity Editor.
Limitations:
data.
updated.
/GLOBAL/INTEGER/
file.
Note: Supported:
Parameters can be imported, exported, and created.
Create and assign parameters on the fly in Entity Editor.
Limitations:
data.
In macros and browser, if any parameterized variable is changed, you will
updated.
/GLOBAL/REAL/
file.
Note: Supported:
Limitations:
data.
updated.
/GLOBAL/REAL_EXPR/
Note: Supported:
Limitations:
data.
updated.
