Visualization
Tools for visualizing orientations, ply shapes and ply layers.
Several types of visualization tools specific to composites are available.
Information that can be plotted includes:
- Composite laminate material reference orientation
- Ply fiber and matrix directions
- Ply shape
- Ply layers of 2D model shown with thickness
Material Reference Orientation
Material reference orientation of composite laminates.
The material reference orientation of a composite laminate defines zero degree fiber direction from which ply orientations rotate. Visualizations are performed using the Material Reference Orientation dialog.
- From the Composite Browser, right-click the white space and select from the context menu.
- In the dialog, click the Material System tab.
Ply Direction
Visualize ply directions.
Ply directions for both nominal fibers and draped fibers can be visualized.
- From Composite Browser, right-click the white space and select from the context menu.
- In the dialog, click the Ply directions tab.
Ply Shape
Visualize ply shapes.
To visualize ply shapes boundaries of selected plies in the modeling window, select a ply entity in a browser or the modeling window. Its boundaries will be highlighted in the modeling window.
Thickness and Layers
Display thickness of ply layers.
For ply-based shell models, the thickness of each ply layer can be displayed using
the visualization options on the View Controls toolbar.
Note: Only
laminate thickness is supported for zone-based shell models. Ply layer
visualization is not supported. The recommended option is to use the Aerospace
Absorb Properties option to convert the zone properties to plies.
Click
Set the shell thickness
option to 3D.
This will visualize the total thickness on each element.
Set the
ply layer and edge option to Ply layers.
This will display the individual layers within each element thickness.
Figure 4. -
Click
Set the face color
to Property.
This will color each layer according to the color of the ply.
From the menu bar, select and type a factor in the ply thickness factor field. Typical values range from 5 to 10.
The thickness of each ply layer is increased.
Figure 5.
