Define Domain for CAERO1 Panel
Use the Panel Mesh tool to select up to four locations to define the domain for the CAERO1 panel.
From the Aeroelasticity ribbon, click the
Panel Mesh tool.
- Select 4 points (x, y, z), 1-2 in chord/flow direction and 1-4 in span direction.
- In the microdialog, define the number of span (NSPAN).
- In the microdialog, define the number of chords (NCHORD).
- Define the table for span (LSPAN), if NSPAN is zero/undefined.
- Define the table for chord (LCHORD), if NCHORD is zero/undefined.
- Define the edge chord length X12.
- Define the edge chord length X34.
Select the aerospace coordinate system CP to define the plane of points 1, 2, 3
and 4.
The CAERO1 ID (EID) represents the element start ID with the ID spanning along point 1 through point 2 and the maximum or end ID at point 3.
Set options as necessary by clicking
on the guide bar.
On the guide bar, click one of the following:
- Save changes/create mesh
and stay in the tool
and close the tool
Tip:
- From the Aeroelasticity ribbon, click the satellite
icon
that appears
when you hover over the Panel Mesh tool to open the Aeroelasticity Browser.
