Generate Results and Reports
Before starting the automated
post-processing procedure, ensure that the crash animation is set-up to the desired
post-processing time step:
- From the MPDB Projection Tool dialog, click Apply to start the entire post-processing procedure for the selected outputs.
Click Save defaults to save all of the data specified in
the dialog in an external file.
Tip: The Load defaults option provides you with an efficient way to quickly retrieve the save default values to be reapplied on a new solver output set of data.
- An automatic Report is generated (in PowerPoint format) containing all of the generated MPDB post-processing results generated by the tool.
